Originally posted by Benz3ne Arrived yesterday and aesthetically it looks great (except for the battery 'door' which is a little corroded). However, the electronics all work superbly, it meters well, winds nicely, the Judas window is seated perfectly and the shutter varies at different set speeds.
The only caveat is that at higher speeds, intermittently, the shutter curtain doesn't return fully, so the mirror sticks up. I've checked that it isn't gummy mirror bumper foam and can confirm that it isn't. Similarly, it's not degraded foam that has stuck to the curtain. I've seen this issue mentioned a few times previously so can assume it's one and the same. I've enquired with Asahiphoto here in the UK as to a repair cost.
On a slight aside, seeing how well the meter works in the new one highlights how my current one isn't quite up to scratch. It's a little flickery during shutter speed changes mostly so I've asked for a repair cost for that (having checked the more external battery contacts, which are all fine).
They're both pretty good, visually, and they mostly work well so I'm keen to get them back to their former glory!
Contact established with Asahi Photo in UK. Will be sending them both off, probably Wednesday, for their inspection and to generate a quote.
Turnaround is approx 10 working days.
For those interested, I had also contacted Alan Marlow, but he's no longer working on MX's.
...I'm still tempted to pick up another MX. They're just so damn nice.
