Originally posted by mlag the first basic check would be what is printed on the adapter, unfortunately it is too much compressed on the picture you share
It says "
OUTPUT DC175V 20mA" and is the same one as in your first link. However it came with a Sunpak Auto130 and I want to use it on later units, for example a Sunpak 30DX, and there is nothing in the 30DX handbook that says what voltage it should be supplied with or what current it takes - it simply says to use an AD27 with no mention of an AD27B or AD27E, despite the fact that the 30DX handbook must have been printed after the AD27B (at least) had been in existence.
It doesn't help that the people who wrote the handbooks and designed the labels on these devices did not know what they were talking about. The 30DX handbook describes the external power supply connection on the unit as an "Outlet" when in fact it is a inlet, and says it is for an "AC" supply when it is in fact for a DC supply, the AC from the mains having been converted to DC by the transformer-rectifier that is the AD27.
I have done a few more detailed tests and I measured the output voltage of the AD27B as 215 v with no load, but it drops to 165 volts when supplying 20 mA (its nominal rating). So it has very poor voltage regulation. Interpolating, it would produce its nominal 175 v while supplying 15 mA although I do not have the appropriate value power resistor at home to test that. I would expect the current draw while charging a flash unit to vary widely (I can't measure it without opening things up) so the voltage would vary widely too. The 30DX handbook says you can attach a 510 v external battery (which I don't have) directly to the same input! The units take just as long to charge with the mains adaptor as they do with internal batteries (about 10 seconds) but the handbook says it charges in only 1 second with the 510 v battery, so I don't know what's going on inside.
Anyway, I have now tried running the 30DX using the AD27B mains adaptor; no blue smoke appeared, and it works fine.
Extract from the Sunpak 30DX Handbook :
I do not think the adaptor for the 510 v plug, shown circled in the diagram, contains any electronics.
For some reason, Sunpak hammerhead units used a different shaped plug from their hot-shoe units despite sharing the external battery pack.
