Originally posted by stormtech Looks a bit slimy Racer X - while it is beautiful country out there your pic makes me kind of glad I only run PA and OH - just the thought of chaining up makes my body hurt. Nice to see the good following distance also.
The long exposure makes it look messier than it really was. The temps were in the low to mid 20's, but the salt the DOT puts down had most of what was on the road pretty mushy.
In all the years I have been driving last Saturday marks only the 3rd or 4th time I have ever had to chain up to continue my journey. And only the 2nd time I had to "throw iron" on a big truck.
Actually, putting chains on an 18 wheeler is not as difficult as one might think. The trailer chains are the cable type, and only the outside tire on one axle is required in Washington. Those were the easiest ones.
The drive tires on the tractor weren't so bad either, but they are considerably heavier. I spread out the chains on each outside drive tire, tuck the leading edge under each one, roll the rig forward a bit, then pull the ends together, hook them up on the inside and then the outside. Then there are 5 cams around the outside chain and a tool that rotates them to tighten the chains up very tight. Then I roll a few hundred feet along the shoulder, stop, and if any are loose I undo the cams, take up another link or two, rest the cams and off I go.
What bites is the distance from where I chained up on the East side of the summit to where I stopped to pull the chains off on the West side was only about 10 miles. A lot of work for such a short journey.
Or maybe I should look at it like this: I only had to run 10 miles with the chains on at 15 mph or so, and once I was able to remove them I was able to cruise along at a decent 45 or so.
And when you are getting paid by the mile, the faster you can go (safely proceeding, of course) the more money you can earn.
And since I am semi-retired, I don't get too worked up over the ups and downs of the job.
I don't have to do it, I do it because it would drive me nuts to be sitting at home all day, every day.
