Originally posted by pepperberry farm seems there are three of these; one is discontinued and has a max load of 3.3 lbs, the current one has a max load of 1.7 lbs, and then there's the wee one for point and shoots...
I found the discontinued one, with the larger payload, at Adorama for $26 and ordered one...
So, my Manfrotto Pocket Support (Large) arrived... model number MP3-D02, which I believe is an older model since it shows as "Discontinued" on some websites. Maximum load is, allegedly, 1.5kg / 3.3lbs.
It's nicely-made - if anything, it feels more solidly built than the small version I have on my Q7.
I fitted it to my old K-5, which happened to have an A50 f/2 lens attached. There's also a very light-weight strap permanently attached to the camera. The weight of this combo is approx. 2lbs / 908g.
The stand works well enough, especially when set up as per the second photo below. However, with the feet at a 45 degree angle or less (see third photo below) on a smooth, low-friction surface, this camera / lens combo is just about on the practical weight limit, as the legs seem to want to flatten out and will begin to creep with only a little downward pressure on the camera. Although I haven't tested it yet, a slightly longer and/or heavier lens would be too much for this little stand, I think. On higher-friction surfaces, it's not an issue, as the rubber feet will grip to some extent - but it doesn't feel as sure-footed as the small version. Lighter cameras such as the K-S1 and K-S2 might be a little better suited.
Overall, for the price paid, it's a nice little stand - and I think I'll use it... but the small version fitted to the Q7 is a better match.
EDIT: I almost forgot to mention... with the stand fitted centrally on the camera, it partially covers the battery door, so leaving it permanently attached isn't altogether convenient. It's not a huge problem, though - just use a coin to loosen the stand's screw half a turn, and rotate it out of the way for battery replacement...
