Originally posted by jeallen01 Re mice, I'm a long time user of the very basic M215 wireless mouse - have probably had about 10 or so (they do fail!) over the years, and I currently have 4-5 actually working on various machines. Quite small and comfortable (surprising as I have quite large hands), and I always try to get the Unifying receivers (but had some of those fail as well).
Can't see the point of the "all singing & dancing" mice - except possibly if you are a dedicated gamer or similar
Wow. I had a Logitech Pilot Mouse (to replace the one that came with my computer and failed within a year or so), which I used for quite a while. Best shape, ever. It was flat, but not too flat. It was comfortable. It works for both left- and right handed people. It did still have one of these heavy balls inside...
Then I can't remember what I had next... it might actually be a Microsoft Optical Mouse? Not sure. After that a more "ergonomic" shaped optical mouse, I believe I bought it because the older ones didn't have USB, and my computer did. No name. That one did fail I believe. It was replaced with a Logitech MouseMan Dual Optical that I bought second hand, which to date after many years of use and then more in storage still works. It did get a bit nasty after a while (rubberized grips, and if you don't continuously use it, the rubber gets disgusting). It also had two sensors at the bottom, for, erm, more precision? Better reliability? To replace it I bought a Logitech G400, also wired, which I used for the next several years, and which is pretty good. Gaming oriented, the successor of the highly successful MX518. It has a very high refresh rate, and very high dpis (3600, vs the 400-1000 that are standard on normal mice). There are buttons to adjust the sensitivity, so if you want to do fine adjustments in Photoshop you could always reduce the sensitivity. It works on many surfaces. Thumb buttons are to far up front, but otherwise it's a good, wired mouse that's also great for daily use. At work I've got a Logitech M705 which works well, and then, for the first time wireless, the MX Master and M720 at home. Got them because I use more than one computer, and don't have the space for several mice on my desk. I can recommend both, and when bought at the right time the price is absolutely fine.
That's the past 22 years in mice, so I used most for many years, and no branded one has failed on me. We'll see how the wireless ones will do.
I have no problem with touchpads either, the one on my little tablet is a bit small, but I can touch the screen if necessary anyway, It works rather reliable. And the giant touchpad of the MacBook Pro works incredibly well. Later MBPs have even bigger touchpads, which may be too much. But the force touch is, ahem, magic. It feels like a regular touchpad where you can click by pushing down the surface, just that it actually doesn't give in. It just feels that way. And because it is not hinged, you can use the same force at any place across the touchpad. I still prefer a proper mouse, though.
Originally posted by WPRESTO At one time or another on one machine or another I've used a wired mouse, a wireless mouse, a trackball and a touchpad. I've pretty much gone to a wired mouse on the desktop, because it has proven the most reliable and durable, and the little touchpad on my laptop, because it's there, and I frequently use the laptop on (gee whizz) my lap.
I'd be curious to know which mice have failed on you, and on jeallen01. The cheap ones I had didn't last too long, but the expensive ones... (initially the Dual Optical was 50 Euro, which was crazy money back then, the G400 around 35 Euro, and the M720 and MX Master were 70 and 100 Euro initially). I'm not worried of them dying anytime within the next 5-10 years.
