Originally posted by UncleVanya Both are 3D. One simply has two dimensions that are the same due to the shape. One could by the logic given say ludicrous things like a sphere is a 1D object which is clearly wrong.
Indeed!
Perhaps the issue is in the distinction between the number of physical dimensions in the physical object versus the minimum number of numerical dimensions required for a description of the object.
In that sense, a sphere is a 3-dimensional object that requires only a 1-dimensional description.
A a cylinder (or lens) is a 3-dimensional object that requires only a 2-dimensional description*.
A simple brick is a 3-dimensional object that requires a 3-dimensional description.
A DSLR body is a 3-dimensional object that might require at least five dimensions of description if we want to more fully describe the upper height of the viewfinder hump versus lower height of the main body or the thickness of the main portion of the body versus the depth of grip.
As for the "tasteful" deployment of SMUs as a universal unit of acquired photographic equipment size, a lens can be measured with a single stack with the number in the stack indicating the length of the lens and the relative width-ratio of SMU-to-lens showing the lens diameter. Using SMUs to show body size of a recently acquired camera might require a stack next to the grip (to show height and depth) and a line of cookies across the back of the camera.
*Obviously, fully describing the size of some lenses might be more complicated with added numbers to describe the size with and without the hood or the added size of a removable tripod foot.
