Originally posted by crewl1 Hey @icrop where are you located?
The shots above look like Santa Fe dam and El Encanto park in Duarte?
If yes you are very close by, may have pay you a visit when you fly that setup.
Hi Larry. I work in Irwindale. Most of the images were taken around there. Yes, you can see Santa Fe Dam and Encanto Park in some of the images.
I typically try not to draw crowds when I fly it (that way there are fewer witnesses if I make a boneheaded mistake
). And at this point I think I have most of the aircraft/photography parameters dialed in. So, I won't be doing many more flight tests, just using it on trips to take aerial photos.
Given the limited capacity of the battery on the Phantom (less than 3 minutes on this last one, as indicated on my web page) these tests don't last long. So, depending on where you're coming from, it might be along drive for a few minute view of the thing flying.
If I take it out locally again, I'll shoot you a PM, giving as much notice as possible.
