11-18-2014, 07:55 AM   #16
reh321's Avatar
QuoteOriginally posted by luftfluss Quote
Yes, I realize this, but for many people who wish to play with their PK lenses, the el-cheapo adapter is a good bet.
Oh, I agree 100% ... but if this strange phenomenon (I've never seen this mentioned with respect o any other camera of any size) were to occur, it is good to understand what happened and how to avoid it.
11-18-2014, 09:23 AM   #17
QuoteOriginally posted by reh321 Quote
I don't think the Q is unique there -- that is how most (maybe all) electronic shutters work with CMOS sensors, and it probably takes longer with bigger sensors (a phone sensor being even smaller than the Q). That 40odd MP Nokia phone actually has a mechanical shutter because of the Xenon flash they used -- it was too fast for the scanning of the electronic shutter. And that very same issue exists with the Q -- shutter speed has to be 1/13s or slower to use flash with shutterless lenses. See this thread:
https://www.pentaxforums.com/forums/136-pentax-q/268300-still-no-external-man...ed-lenses.html
11-18-2014, 10:24 AM   #18
reh321's Avatar
Do iPhones have an electronic shutter?? I've taken pictures of moving trains with my iPhone with no sign at all of this phenomenon.
My Canon Elph, the camera I 've been thinking of replacing by a Q, has a sensor the size of the sensor on a Q or Q10, but I've never seen that phenomenon with it either.
In fact, despite using various small cameras, I had never heard of this phenomenon before encountering here, which is why I asked so many questions.
Frankly, I view this as a weakness of the Q family. If other small cameras don't have this problem, or it shows so seldomly that someone like me would never encounter it, then I don't understand why it is a known issue .with the Q-family.
11-18-2014, 10:55 AM   #19
It is called a "rolling shutter" and people complain about it all the time (especially for video) on all sorts of cameras. Jello shutter, "shudder", smear...these terms were not invented just for the Q. It is just a property of CMOS sensors (whereas CCD sensors generally don't work that way). It isn't like Pentax is making their own sensors (is the Q sensor a Sony? Can't remember) -- it is likely the same sensor is in some other cams.
Here's some people that like the effect:
http://blog.flickr.net/en/2010/08/24/rolling-rolling-rolling-shutter/
https://www.flickr.com/search/?q=%22rolling%20shutter%22&w=all
11-19-2014, 03:21 AM   #20
drypenn's Avatar
The 03 (fisheye) can also be use sparingly for some interior shots to exaggerate space.
11-20-2014, 10:00 PM   #21
johnmflores's Avatar
TBH, I don't think that the Q7 is well-suited for Real Estate photography as it just doesn't have the low light performance or dynamic range needed. For that kind of work, it helps to have a camera that'll give good images at ISO1600 and beyond for those dark, dim basements and other moody rooms.
You might want to check out the Sony RX100 line of cameras and find the one with the widest wide angle. Ideally, get something 24mm EQ or wider, the wider the better, unless it's a fisheye, then no. AFAIK, the low light performance of the entire line is pretty similar so you might be able to save some money by buying used. I'd also suggest a cheap monopod to help steady shots in low light.
If you do give the Q7 a try, she'll really need the 08. The 02 isn't wide enough and the 03 is too distorted, too slow, and manual focus.
Good luck!
03-09-2015, 08:58 AM   #22
As a Realtor that shoots his own listings, ultra wide angles are needed, especially for small rooms. I use a K-01 with a Sigma 10-20 wide angle lens. Fast apertures aren't needed as tripods and deep DOF are required to show the house in focus.
03-11-2015, 03:19 AM   #23
sapporodan's Avatar
Ricoh GR with the wide angle adaptor would give a very sharp 21mm field of view, plus its small enough to easily carry around.
03-17-2015, 11:06 PM   #24
Alas, 21mm is still not wide enough for small or stuffed with furniture rooms.
06-20-2015, 01:43 AM   #25
Transit's Avatar
QuoteOriginally posted by tabjohnson Quote
I agree.
Waste of time using K adapter with Q for RE, all lenses become long not wide
06-24-2015, 08:54 AM   #26
BTW. . . I picked up the Q7 Premium Kit off eBay -- from Japan -- for $762 with free shipping. That included the 01, 02, 06 and 08 lenses all with their lens hoods, and a polarizing filter, and the custom bag to carry it all. Seems like a bargain. However, that's "gray market" without valid warranty in the USA.
06-25-2015, 04:57 PM   #27
QuoteOriginally posted by Tony Belding Quote
This is such a great deal. I should do this to get the 08...
cameras, digital camera, future, lenses, mirrorless, q7
could ISO 80 be possible on the k3 with a future firmware update? Rice Pentax K-3 2 05-19-2014 09:21 PM
Possible Freelance Kit / Need Help With Equipment drewdlephone Pentax Film SLR Discussion 9 06-22-2009 09:46 AM
Is it possible to have an electronic range finder feature in future Pentax DSLR? fearview Pentax News and Rumors 13 04-01-2009 05:15 AM
Little help? help me identify possible problem and lens mount. mediaslinky Pentax SLR Lens Discussion 4 08-23-2008 06:32 AM
Help with possible 50 1.7 A issue dstoepfel Pentax SLR Lens Discussion 12 04-28-2007 01:56 AM
All times are GMT -7. The time now is 08:40 AM. | See also: NikonForums.com, part of our network of photo forums!
