05-23-2012, 04:07 PM   #91
Blue's Avatar
QuoteOriginally posted by audiobomber Quote
I don't see anything entry-level about this camera. The marketing manager for Pentax Americas said they refer to it as a mid-level DSLR. Entry level cameras don't have two wheels or weather-resistance.
K-5 has 14-bit raw vs 12, ISO 80 vs 100. K-5 has a few more switches (metering mode, separate buttons for AE-L & AF, AF Select), where the K-30 has menus. Metal body vs. metal frame & polycarbonate body. ISO performance should be equal, maximum dynamic range should be about 1.5 stops higher in favour of the K-5, resolution is equal. The K-30 has focus peaking for manual focus in Live View, better video mode (I don't know the details because I don't care about video) but the K-5 will allow an external mike. K-30 is slightly smaller & lighter, battery won't last as long (half as many shots?), but the K-30 can also use AA's. K-30 has more WR seals and improved AF. K-30 is priced lower. That's all I can think of.
Don't forget the faster shutter on the K-5 (1/8000) as well as the HDMI jack, external mic jack and external remote jack. The K-5 also takes an optional grip.
05-23-2012, 05:17 PM   #92
audiobomber's Avatar
QuoteOriginally posted by loco Quote
How does the K-30's prospective DR capabilities compare to the K-r? If it's not quite up to K-5 standards, how much better than the K-r do we expect it to be?
It should be equal to the K-01, so 12.9 Ev vs. 12.5 for the K-r.
05-23-2012, 05:20 PM   #93
Thanks, looks like I forgot a few K-5 advantages. I did mention the microphone jack, I wasn't aware there was no jack for exteral remote.
05-23-2012, 06:08 PM   #94
loco's Avatar
Thanks!
05-23-2012, 06:58 PM   #95
Look at the K-5 and K-01, it's going to be somewhere close to that.
QuoteOriginally posted by eddie1960 Quote
the T4i will of course outsell it 4 to one though maybe less with the K-30 going into Target (and probably some other big stores)
If Pentax manages to market the K-30 really well, it could match the Canon two to one (if the Nikon D5200 goes the same way as the D3200; I doubt the Nikon counterpart will have WR nor pentaprism nor 2 user modes... but it will have mic input and battery grip option I guess)
05-23-2012, 07:23 PM   #96
QuoteOriginally posted by Alizarine Quote
There is a large gap in DR between the K-5 and K-01. The K-30 will be like the K-01 raw engine, not like the K-5.
05-23-2012, 07:28 PM   #97
It's hard to tell exactly how large that gap is unless it's viewed on charts and stuff. Comparing the K-30 to the K-r makes the K-30 closer to the K-5 right? as that was what he was asking; "how much better than the K-r"
05-23-2012, 07:32 PM   #98
Blue's Avatar
I am not 100% on the external remote, but I have read that was the case. I hope I am misinformed on that.
05-23-2012, 08:34 PM   #99
vinceloc's Avatar
I'm curious about the "Pentax Hand Strap" which photographyblog.com mentions as an optional accessory. Can any pictures be provided on this?
05-24-2012, 04:52 AM   #100
The official specs are shown now at Pentax Imaging, There is a jack for wired remote:
- Cable switch: Yes (available separately)
PENTAX - K-30 Black
QuoteOriginally posted by vinceloc Quote
The Pentax hand strap is not just for the K-30, it fits all Pentax DSLR's. Here it is on the Pentax site but it's available for sale all over the world, just Google it.
http://www.pentaximaging.com/accessories/DSLR_Leather_Hand_Strap
05-24-2012, 05:14 AM   #101
Graphs are available at DXOMark if you substitute the K-01 for the K-30. There is no reason to expect the K-30 to be different than the K-01. From anything I've seen, they have the same sensor and same 12-bit raw processing engine.
Mostly when people talk about dynamic range, they quote the maximum available DR:
K-01/K-30; 12.9 Ev @ ISO 100
K-r; 12.4 Ev @ ISO 100
K-5; 14.1 Ev @ ISO 80
The graph shows the K-01 gradually gains ground up to ISO 1600, where it is half a stop lower than the K-5 (9.88 vs. 10.35 Ev). At ISO 3200 and beyond, where Pentax adds non-defeatable noise reduction, the K-01 and K-5 DR are equal, but the K-5 has a slightly higher signal-to-noise ratio.
DxOMark - Compare cameras side by side
05-24-2012, 05:27 AM   #102
french_mike's Avatar
and will fit any D-SLR
05-24-2012, 10:32 AM   #103
Less for less - According to pentaximaging.com specs
"IMAGE STABILIZATION Type: Sensor-shift SR w rotational compensation (3 stops max)".
Adam should want to add this to the specs comparison page. I believe K-5 has four stops max.
Definitely dumbed down if this proves correct.
Source: PENTAX - K-30 Black
05-24-2012, 11:50 AM   #104
QuoteOriginally posted by solar1 Quote
Good find. I looked at the K-r spec because IIRC, the K-5 and K-7 had rotational compensation that other Pentaxes did not, but the K-r claims four stops. It's hard to believe the K-30 SR would be less capable than the K-r. Maybe they're just trying to be more truthful.
05-24-2012, 12:50 PM   #105
builttospill's Avatar
Why do people keep saying there's no wired remote plug in this camera? The wired remote symbol was clearly visible on the door in early leaked photos.
k-30, k-50, pentax, pentax k-30, pentax k30, pentax k50, specifications
Official Pentax K-01 Specifications Revealed Adam Pentax K-01 60 02-26-2012 05:56 AM
Pentax Q mirrorless: Specifications and lens details posted! Adam Pentax Compact Cameras 301 08-01-2011 08:57 AM
Pentax Japan full K-5 Specifications jogiba Pentax News and Rumors 2 09-21-2010 08:08 PM
Pentax K-5 and KR Specifications Adam Pentax News and Rumors 52 09-14-2010 04:46 PM
Looking for vintage Pentax lens Specifications pentaxographer Pentax SLR Lens Discussion 12 08-26-2008 06:07 AM
All times are GMT -7. The time now is 11:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
