Show Printable Version 11 Likes Search this Thread
05-27-2012, 07:19 PM   #121
Yes the AF in the K-5 was way behind the 7D for sure. If they can get it up to the 7D level and update the lenses to match for speed. Then and only then will anyone take it seriously for sports really. I am using one of the new Canon lenses and it is just accurate and fast in C or Servo mode. I am thinking years for this to happen with Pentax. Hope I am wrong but I am on the fence until that happens.
One other thing is the SR or IS in Canon. The new lenses really smack around the K-5. That really needs a refresh also. Very bad.
They will never catch up now. But I am hoping they will have a camera soon that I can buy to suit my needs. Good enough is all I want with Pentax for my photography.
05-28-2012, 12:02 AM   #122
QuoteOriginally posted by garyk Quote
Not just sports, the 7D is also famous with wedding and events photographers. Until Pentax AF matches Canikon AF accuracy and speed will only most pro's in those fields consider getting a Pentax. I just hope that even during the short time of Pentax's acquisition from Hoya, Ricoh has already made leapfrogs in AF technology to be released in this year's models.
As for the SR, if Pentax can outperform Olympus' 5-axis IBIS...
05-28-2012, 12:12 AM   #123
ogl
Banned
According to Pentax, the new AF system in the K-30 addresses many of the shortcomings of previous Pentax DSLRs. Do you think Pentax will finally be closer to the competition with the launch of this camera?
Which models of Canon and Nikon do you mean?
I prefer smaller and more accurate and more sensitive sensors of new Pentax AF.
And more AF points. At least 15 or 19.
11 AF points in K-30 with the same big sensors even with upgraded algorithms - it's hard to say - if it will be the radical cure for Pentax AF. I will see...
05-28-2012, 08:08 AM   #124
My last two photo-events have been ruined by unusually large AF sensors... so I'm particularly perturbed about this right now!
05-28-2012, 09:09 AM   #125
Anvh's Avatar
QuoteOriginally posted by Alizarine Quote
5 axis?
If the sensor moves forward and backwards as well i doubt that will do any good for the sharpness since you will be changing focus essentially...
05-28-2012, 09:11 AM   #126
Anvh's Avatar
QuoteOriginally posted by ElJamoquio Quote
Are you talk about the physical size of the sensor or the size it measures with?
Since you clearly say "AF sensor" but i think you mean "AF point"
05-28-2012, 02:16 PM   #127
QuoteOriginally posted by Anvh Quote
He's clearly talking about the AF point sensor size...
05-28-2012, 03:29 PM   #128
Effective AF also interacts a lot with the lens used (eg this table, for Canon AF). Some lenses are better than others in supporting good AF.
Sometimes good AF may be a trade off too - your sharpest or fastest lens may not be your best AF performer.
05-28-2012, 04:29 PM   #129
The AF points are pretty small, especially compared to the actual sensors. Like many others, it sounds like he thinks the sensors and the area they cover are too big.
05-28-2012, 04:39 PM   #130
I know the area that my sensors cover is too big for the shooting I try to do. I just did a test where a lens alternatively would back focus two cm and front focus two cm when given a chance on a striped target with apprx. 2 cm pattern.
05-28-2012, 04:47 PM   #131
05-28-2012, 06:17 PM   #132
Anvh's Avatar
It's about as large as the circle in the middle.
05-29-2012, 02:00 AM   #133
aurele's Avatar
i would even say that it might be slightly bigger and cover out of the circle a bit.
05-29-2012, 03:31 AM   #134
With the K-x yes it's probably around that big... it's frustrating at times.
05-29-2012, 04:18 AM   #135
aurele's Avatar
indeed.
I hope the K5 remplacement will have smaller AF points
af, focus, k-30, k-50, lens, module, pentax, pentax k30, pentax k50, sensor, sensors, subjects, system
Pentax vs Canikon (English Assignment) jellyfish26 General Talk 11 10-05-2011 06:31 AM
Wow, this guy really hates the K5 and says Pentax is 2 generations behind Canikon crossover37 Pentax K-5 & K-5 II 131 05-16-2011 10:36 PM
Pentax K-5 beats Canikon -- that's the cover story in Germany now falconeye Pentax News and Rumors 53 02-27-2011 03:40 PM
We hear about people switching to Canikon, anyone switched from Canikon to Pentax? Eric Seavey Pentax DSLR Discussion 22 08-08-2010 06:54 AM
interesting nikon/canon rival survey kenyee Pentax DSLR Discussion 12 12-19-2007 07:36 AM
All times are GMT -7. The time now is 05:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
