06-16-2012, 01:21 PM   #46
Using a low dispersion glass combined with a high index Barium glass could have easily solved the CA problem Pentax had. However, it is my belief that DO was used instead, more as a space savings option to the bulkier traditional CA solution.
06-16-2012, 02:03 PM   #47
QuoteOriginally posted by desertscape Quote
...maybe they wanted something patentable...just a little jaded
06-19-2012, 12:52 PM   #48
Ryan Trevisol's Avatar
QuoteOriginally posted by Anvh Quote
As far as i know the system is sensative for light not colours, but yeah it might be more sensative for certain colours...
I think the point being made is that if CA occurs on the image seen by the AF sensor, the different wavelengths being split and appearing across a wider area would both confuse the AF sensor and make that area appear out of focus.
06-19-2012, 05:26 PM   #49
Anvh's Avatar
QuoteOriginally posted by Ryan Trevisol Quote
I know and that wasnt the discusion.
06-21-2012, 01:01 PM   #50
QuoteOriginally posted by Asha Quote
garyk, the Schmidt plate is an asphere, not a diffractive element. In the original design, the Schmidt corrector is mainly for spherical aberration in a spherical mirror (reflective telescope). A diffractive optical element is more along the lines of a Fresnel lens. It DOES have optical power, ie, it behaves much as a "normal" lens would, but with subtle differences. Plus, it can be made more flat and thus make for a more compact system.
Ok, thanks
Just looked it up.. Chromatic aberration is where different wavelengths focus at different points on the focal plane and spherical aberration is where the Focus is focused at different points on the focal plane. Looked at a diffractive optical element design also. I know squat about AF but i think I will look into it. I see where a DO element can reduce optical elements in the lens also. Interesting thread.
aberration, af, canon, characteristics, diffractive, glass, k-30, k-50, lens, optics, pentax k30, pentax k50, system
Lcd magnifier with best optics? barondla Pentax Q 2 03-18-2012 09:45 PM
Lens optics cleaning help icejam Troubleshooting and Beginner Help 9 08-09-2011 03:55 PM
Nikon Q system using 1/2.3" sensor too = Pentax Q system? ogl Pentax News and Rumors 31 07-14-2011 07:47 PM
DXO Optics Pro v6.5 now available rawr Digital Processing, Software, and Printing 9 11-11-2010 05:07 PM
Continental Optics Lens? SweetSherri Pentax SLR Lens Discussion 12 06-28-2010 06:34 PM
All times are GMT -7. The time now is 06:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
