Originally posted by Anvh I believe i said that and why it doesnt work for me, the K5 work the same way with the AF but it has a dictated ISO button.
I must have missed that part.
You can also program the RAW/Fx button to switch the cursor functions between AF selection and regular mode.
This is faster than holding OK in the middle.
Quote: Anyway do you go into ISO menu with that button or can you change the ISO with the front dail then?
When you press the ISO button, it shows an ISO screen on the rear LCD.
You can then switch the ISO mode with the dials, and then you can just press the shutter to focus. There is no requirement to press OK to validate to exit that ISO screen, though you can do that too if you want to go back to the main screen and change other exposure settings.
When the ISO screen comes up, if you are in auto-ISO, the front dial changes the minimum ISO, and the rear dial the maximum ISO.
If you are in manual ISO, the rear dial decreases the ISO and front dial increases it.
To switch between manual and auto ISO, you use the up/down arrows.
How is that different on the K-5 ?
So it comes down that you need to chose;
Quote: AF or exposure lock
A button for AF isn't really needed IMO, when the shutter button can just be half-pressed.
Leaving it programmed for AE-L is fine and means you have 2 different buttons for these 2 functions.
Quote: ISO or AF selection
On the K5 all these function have their own dictated button so you can use them all at the same time.
Honestly pressing one button (RAW/Fx) to go to AF selection isn't so bad. I never need to change file format so frequently, certainly not between individual shots, this is more like a once-a-day thing or less.
