Originally posted by JPT Overall, it looks like the K-30 is a great camera and does most of what the K-5 can do, plus the extra live view stuff that came with the K-01. If build quality is at the top of your list of priorities, however, the K-5 is clearly better constructed.
Nice write-up.
But from what I experienced, the shutter in K-30 is definitely different from the one in K-r or K-x. It's a bit quieter w/ less hesitation.
One thing you forgot to mention is that the grip on K-30 is a better design even than K-5. There is more space on the back where the thumb rests, not like K-5 which has a couple of buttons there, and the rear dial is too close to the thumb on K-5. The K-30 grip is a bit deeper but narrower, the rubber used is a bit stickier too so you'd feel more secure when holding a K-30 than a K-5, especially w/ a longer heavier lens mounted.
Another change from K-5 is that the LCD screen on K-30 seems to be sharper and more saturated than the one on K-5. Even looking at the menu (text), the one on K-30 just looks a lot better. Same photo would appear sharper w/ a lot better colors on K-30's screen than on the K5's.
As I said in the other thread, I don't mind getting a K-30 if choosing between these two. The only thing I'd miss is probably the bigger capacity battery used in K-5, but I'd gain better grip, better LCD, better video, slightly better AF, better MF w/ focus peaking and sharper LCD ...
