06-21-2012, 01:10 PM   #16
Ryan Trevisol's Avatar
QuoteOriginally posted by RobA_Oz Quote
I don't think that's correct. If you shoot RAW+, then the JPEG image will have NR applied (very effectively, too, especially with the Q) but as far as I can see, the RAW image is untouched, as it should be. Do you have a source for this?
Anvh, you're making it sound like some kind of NR is happening and you can't turn it off. True, high-ISO NR is on by default but can be turned off in the Rec Mode 3:
From the K-5 AND K-30 manuals:
Auto
____Applies Noise Reduction at optimally calculated levels throughout ISO range. (default setting)
Low/Medium/High
____Applies Noise Reduction at constant chosen level throughout ISO range.
Custom
____Applies Noise Reduction at user-defined levels for each ISO setting.
Off
____Does not apply Noise Reduction at any ISO setting.
Are you saying there is another level of NR being done regardless of this setting?
Edit: looking at the DNG files that ImageResource posted, it certainly doesn't look like NR was applied to the raw images. They all look dramatically better but there's still some loss of detail on the shot of the chain links. (look at the threads of the chain link)
06-21-2012, 04:26 PM   #17
QuoteOriginally posted by Aegon Quote
Engadget put the camera under a water spout.
That's like crashing a car to make sure the airbags work. Kinda.
You think that's crazy? Take a look at this:
I plan on giving the K-30 the same treatment this evening. Review should be up next week.
06-21-2012, 07:05 PM   #18
Anvh's Avatar
DXO mark and their tests with the K5 and K30, i believe other reviewers also have noticed this behaviour but RAW above ISO 1600 is certainly not untouched.
06-21-2012, 07:19 PM   #19
Anvh's Avatar
QuoteOriginally posted by Ryan Trevisol Quote
Yes precisely and you cant turn it off
Here are the reviews i talked about.
DxOMark - DxOMark review for the Pentax K5
Smoothing appears at ISO 3200 but does not impact the metrics.
Pentax K-5 Camera Raw - Full Review
Here, we can see the Pentax K-5 clearly produces the cleanest looking RAW files, though it appears to be applying some noise reduction at higher ISOs (above ISO 1,600), which cannot be turned off. The noise reduction applied is pretty subtle, though, nothing like the heavy-handed approach used in earlier Sony SLRs. Still, it's something we'd rather not see in RAW files, as it does impact fine detail.
htpp://www.dpreview.com/reviews/pentaxk5/12 spellings mistake fixed
A quick glance at the graphs shows us that the Pentax K-5 produces the best measured results in this test followed by the Nikon D7000 (which uses a very similar sensor); the Canon EOS 60D and Olympus E-5 are not quite on the same level. A closer look at the graphs, though, reveals a clear kink in the K-5's noise graphs at 1600, indicating that the camera applies some noise reduction even to the raw files.
I believe tis clear now
06-22-2012, 10:56 AM - 1 Like   #20
QuoteOriginally posted by jpfisher Quote
Is that a 645D? Whoa...
06-22-2012, 03:53 PM   #21
Here's what I shot during my first day with the camera: 2012-06-20 - Pentax K-30 Shooting Event - jimfisher's Photos | SmugMug
06-22-2012, 06:21 PM   #22
Your collection is significant enough that I think it deserves a thread of its own! You wouldn't want your link to it to fade into obscurity in my soon-to-be-forgotten thread, would you?
P.S. Judging by some of your pictures, you appear to be the person who shot the K-30 video on Engadget. Right? Either that or you were sitting right next to that person.
06-22-2012, 07:04 PM   #23
QuoteOriginally posted by Welfl Quote
Just sitting right next to him.
if you looked at my gallery earlier and saw some duplicate shots, I fixed those. Smugmug uploader has been finicky as of late--it also missed 8 shots that are now up as well.
06-22-2012, 10:27 PM   #24
Ooh! I love the colors!
06-24-2012, 09:54 PM   #25
Crazy it is, but this doesn't look like a K-30, but the 645D !
images, iso, k-30, k-50, pentax, pentax k30, pentax k50
K-r Focus Test with Images krebsy75 Pentax K-r 33 12-24-2011 12:48 PM
Q test with images and high iso test pictures StigVidar Pentax Q 9 10-05-2011 08:23 PM
645D test images Billgscott Pentax News and Rumors 6 12-13-2010 01:04 AM
Chasseur d'Images test of 20 Pentax lenses on the K20D thibs Photographic Industry and Professionals 47 06-24-2009 06:14 AM
Test images with the new Pentax 55mm Sila Pentax SLR Lens Discussion 6 09-24-2008 12:47 PM
All times are GMT -7. The time now is 11:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
