07-06-2012, 09:55 PM   #1
DebLewis's Avatar
Remote for K-30?
Can you use a remote with the K30?
07-06-2012, 10:07 PM   #2
ramseybuckeye's Avatar
QuoteOriginally posted by DebLewis Quote
Yes, but I think it only receives from the front of the camera. The manual is online.
07-06-2012, 10:56 PM   #3
DebLewis's Avatar
Thank You
Yes there is a remote, waterproof at that and the sensor is on the front of the camera.
07-07-2012, 03:06 AM   #4
I just noticed that the K-30 manual says (p-120) that normally when using a remote control you cannot adjust the focus.
But when using the Remote Control Waterproof O-RC1, the autofocus system can indeed be operated remotely, via the button in the middle of the remote control. It works the same way with the K-5, apparently. Very handy.
You learn something new every day.
07-07-2012, 04:42 AM   #5
FruitLooPs's Avatar
Just for clarity, there is still the option in the cameras settings for having the AF work prior to releasing the shutter when using the remote. "AF with Remote Control" no. 14 in the menu Fancy remote sounds nice though.
07-07-2012, 05:16 AM   #6
QuoteOriginally posted by FruitLooPs Quote
Ooops, my bad.
Of course, the manual does indeed say: "When [14. AF with Remote Control] is set to [On] in the [A Custom Setting 2] menu, you can use the remote control unit to adjust the focus. "
I was half-recalling a discussion in the K-5 subforum where someone was complaining about the in-ability of the camera to do AF when using the self-timer - eg for self portraits or group shots.
Doesn't look like that has changed with the K-30.
04-23-2013, 12:29 AM   #7
Does anyone have a specific model of remote that will work with the K-30?
04-23-2013, 01:03 AM   #8
I got 2 of these IR Wireless Remote Control for Pentax K7 K5 K100D K110 K20D K200D K20 KR KX KM | eBay and just leave them in their own little plastic bags to protect them in case of raining. Oh, they work very good in few feet ..... but I have not check for their maximum range though.
04-23-2013, 01:27 AM   #9
dragra's Avatar
You have also an option for wired remote, K-30 has a socket for it right under the card door.
04-26-2013, 07:54 AM   #10
Ooops, my bad.
It certainly can use that feature. I did a year of self-portraits with the K5 and K30 using a remote on 3 second timer and had the AF with remote feature turned on. It worked just fine.
04-26-2013, 04:50 PM   #11
I had an old universal TV remote laying around and programmed it with a code that I found online and it works great . Also you can change the batteries unlike the Pentax remotes . Kind of a redneck remote LOL .
04-27-2013, 02:08 AM   #12
QuoteOriginally posted by Ken T Quote
That's the remote I bought, it works well in all the rooms in my house and often works from behind bouncing off walls. I also tried a little bit of silver foil taped at an angle over the sensor and then it worked reliably from behind.
I bought a £5 wired remote off Amazon UK, search on 'PowerPlanet compatible Pentax CS-205 wired remote cord for PENTAX'. That also works fine and has a half-press/full press type of shutter switch. The K-30 isn't mentioned in the compatibility list but it definitely works.
04-29-2013, 05:21 AM   #13
I purchased this remote from Amazon.com for my Kr and it works with the K30 see the reviews.
FYI, I purchased it from the same company and they were very quick with no problems.
04-29-2013, 01:55 PM   #14
simone's Avatar
QuoteOriginally posted by jeffw Quote
How did you do it? Please teach us.
Thanks
04-29-2013, 02:30 PM   #15
crewl1's Avatar
QuoteOriginally posted by simone Quote
Thanks
https://www.pentaxforums.com/forums/pentax-dslr-discussion/738-ist-d-infrared-remote-code.html
k-30, k-50, pentax k30, pentax k50
PENTAX Waterproof Remote Control O-RC1 vs. Remote Control F jpzk Pentax Camera and Field Accessories 8 12-02-2013 08:11 AM
For Sale - Sold: Pentax Remote F IR remote (CONUS) Ed n Georgia Sold Items 2 03-28-2011 03:01 PM
Remote control for Pentax: PocketPC app. (alternate to Pentax remote) dragonfly Troubleshooting and Beginner Help 4 08-12-2010 10:22 AM
K-x remote Muse Pentax DSLR Discussion 7 08-11-2010 09:34 PM
Using Harmony Remote for Pentax Remote mateojives Pentax Camera and Field Accessories 12 04-30-2009 11:29 PM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
