07-19-2012, 04:51 AM   #16
I use the Upstrap. It's a strong nylon or kevlar web with a wide rubber pad attached. I can carry my K7 and Sigma 70-200 all day, with no problem.
Camera Strap Professional Non Slip Camera Straps - UPstrap
Regards
07-19-2012, 05:10 AM   #17
Docrwm's Avatar
https://www.pentaxforums.com/forums/pentax-camera-field-accessories/192529-ca...ggestions.html
07-21-2012, 04:58 AM   #18
Raffwal's Avatar
I guess I have to give a wrist strap a try as well. I usually just use the neck strap wrapped a couple of time around my wrist and hold the camera by hand. But obviously using a sliding strap like that, it can't hold the camera's weight. I just spent a few days using a camera like that and because I had to in effect hold my K-5 most of the time, I developed a slight case of lateral epicondylitis, the tennis elbow.
07-22-2012, 07:20 AM   #19
kkoether's Avatar
I should have mentioned that the Pentax wrist strap I use will also allow you to connect a neck strap. I tried that when I fist got my wrist strap but found the extra strap cumbersome. YMMV.
07-22-2012, 08:33 AM   #20
Tom S.'s Avatar
QuoteOriginally posted by kkoether Quote
2 weeks ago when I was at the Madison Regatta it was in my hand pretty much the hole day. I also was carrying my LowePro AW200 sling bag if I needed a break. The Pentax hand/wrist strap I find is very comfortable. It doesn't require a death grip on the camera when your not shooting.
Here is the one I use.
PentaxWebstore.com:DSLR Leather Hand Strap DSLR Leather Hand Strap
The problem with that strap is it will not work if you use the battery grip accessory.
07-22-2012, 10:18 AM   #21
kkoether's Avatar
It does on mine. The battery grip never leaves my camera.
07-22-2012, 11:33 AM   #22
Tom S.'s Avatar
Hmmmm, then Pentax lied on their website:
"This finely crafted leather hand strap comfortably secures the camera to the shooter's hand, decreasing muscle fatigue for those long hours behind the lens. It's perfect for the walkabout photographer, keeping the camera always at the ready A quick-release tab loosens the strap with a tug, allowing the photographer to easily slip his/her hand into or out of the strap. Compatible with all DSLR camera bodies. Doesn't fit the D-BG4 battery grip."
Oh, wait - you're not using that battery grip. Anyone with a K7 or K5 is sol.
07-22-2012, 11:49 AM   #23
Docrwm's Avatar
QuoteOriginally posted by Tom S. Quote
He has a D-BG3 on a K200D.
07-22-2012, 01:41 PM   #24
kkoether's Avatar
Maybe that's the difference. Wonder what they did with the D-BG4 that won't let it work? Maybe the placement of the threaded adapter hole?
07-22-2012, 01:45 PM   #25
Docrwm's Avatar
Tripod attachment is offset in the BG4, I'm not sure but that may be it.
07-22-2012, 01:54 PM   #26
kkoether's Avatar
On the BG-3 it's offset to the right as viewed from the rear. If it's offset to the left it wouldn't work because the strap would be too short. Something else to consider if and when I upgrade.
07-22-2012, 01:56 PM   #27
Moo
One problem I see with most of these "alternative" straps is that by having something screwed to the bottom of the camera, it prevents it being stood normally on its base. The photo kkoether posted suggests that strap may have the same problem too, but not as bad as some...
07-22-2012, 07:57 PM   #28
Eric Auer's Avatar
Domke Gripper worn on the Shoulder. It stays put with all cameras I have.
I would never wear anything around my neck.
But that's just the "Street kid" in me.
07-22-2012, 08:33 PM   #29
lammie200's Avatar
QuoteOriginally posted by Moo Quote
That is one reason why I went with a Camdapter system. Last time I am going to say it - I promise.
Camdapter
07-23-2012, 08:20 AM   #30
My Crumpler Singapore Slim turned up over the weekend. Very happy with it so far, much more comfortable than the stock strap. Also allows you to turn it into a sling/shoulder strap very quickly with quick release buckles. I'll try to post a full review after I've used it a bit more.
k-30, k-50, neck, pentax k30, pentax k50
Neck strap K5_Ltd_User Pentax Camera and Field Accessories 24 05-07-2012 10:31 AM
K-5 Neck Strap Holders Glen Pentax K-5 & K-5 II 4 07-19-2011 09:10 AM
Need thin neck strap TOUGEFC Pentax Camera and Field Accessories 22 05-16-2011 12:42 PM
Neck Strap Issue Has Struck My K-7 Nowhere Matt Pentax DSLR Discussion 12 11-02-2010 02:00 AM
Goodbye to neck strap; Hello Wye Strap!!! philbaum Pentax Camera and Field Accessories 42 08-12-2010 01:39 PM
All times are GMT -7. The time now is 06:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
