Originally posted by i_trax In K-30 there is a surprising option in M, you can set ISO to AUTO but Green Button will not perform Stop Down metering with manual lenses.
After downloading the pdf manual I have discovered that:
"If the mode dial is set to M when the sensitivity is set to [ISO AUTO] , the camera operates in TAv mode."
Turning the LCD off is a bit fiddly, you can not just toggle INFO button like you could on Q, K-x,K-5&K-7, it requires few more steps.
Magnifying in Live View is again a bit confusing, all those matters could be easily fixed with firmware update.
Camera is well build but it feels much more like K-x/r than K-5/7, IMO the MENU button is too close to WB ( four-way controller) , I keep entering the MENU instead of selecting the options but I am pretty sure I will get use to it.
It should definitely be supplied with AA adaptor as a standard accessory.I had plenty Eneloops ready to go, I had to wait for hourd for the charger to charge the supplied rechargeable instead, before I could turn it on. My AA adaptor on the back order.
Nevertheless K-30 is an another example of excellent Pentax engineering indeed.
i_trax, I am having trouble getting a non A series manual Takumar to stop down. I was told if I turn off the auto iso that would allow the camera to down stop when the picture is taken. Trouble is that having done a fair amount of looking, I have not been able to find out how to turn off auto iso. Would be much obliged if you could provide the steps. Then, if I understanding correctly, when I take the picture the camera actually actuates the aperture to the f stop I have set the dial on the lens to?
