07-30-2012, 07:23 AM   #1
Indopunk's Avatar
KX Owner Looking To Upgrade To The K30
Can anyone tell me if there's a discernable difference in quality/performance between the 18-55 mm kit lens that came with my KX and the 18-55 mm kit lens that comes with the new K30 or are they virtually the same (other than my kit lens being white in color)?
07-30-2012, 07:24 AM   #2
JinDesu's Avatar
They are optically the same. The one that comes with the K-30 is the AL II while yours is the DAL. The main difference is the AL II has a metal mount and supports quick shift.
07-30-2012, 07:38 AM   #3
boriscleto's Avatar
QuoteOriginally posted by JinDesu Quote
Actually the K30 kit is the same DA L that came with the K-x.
07-30-2012, 07:42 AM   #4
JinDesu's Avatar
QuoteOriginally posted by boriscleto Quote
Oh - woops, I must be thinking of the lens on the k-5. I know one of the 18-55s I played with at B&H had quick shift, which is not available on the DAL.
Thanks for correcting me.
07-30-2012, 08:03 AM   #5
Indopunk's Avatar
Thanks JinDesu and boriscleto for your responses. I was asking because I'm deciding on whether to get the white K30 with- or without the kit lens. If they are virtually the same, then I can save myself 50 bucks and will get only the white body. Too bad they don't offer the 18-55 mm WR lens as a package.
07-30-2012, 08:05 AM   #6
I'd get the 18-135WR kit, personally.
07-30-2012, 08:08 AM   #7
JinDesu's Avatar
QuoteOriginally posted by deadwolfbones Quote
I would double agree with this - it is an additional $300, but it gives you a WR kit that has more reach than your 18-55, silent motor, and quick shift.
07-30-2012, 08:28 AM   #8
Whoops, wrong thread..
07-30-2012, 08:38 AM   #9
Indopunk's Avatar
Newbie here..What is quick shift and why would I want it?
07-30-2012, 08:42 AM   #10
JinDesu's Avatar
QuoteOriginally posted by Indopunk Quote
Quick shift is a technology on the Pentax lenses (and there is a similar tech for Canon/Nikon lenses) that allow you to manually adjust the focus even while on autofocus mode.
For example, your DAL 18-55 on the k-x, if you are in autofocus mode, any attempts to rotate the focus ring will result in a nice grinding sound as you are turning the in-camera motor. Quick shift uses a clutch mechanism that allows you to turn the focus ring and disengage the autofocus motor - making it easier and preventing damage to the in body motor.
Reasons why you would use quick shift:
In low-light situations where the camera can do micro adjustments to get AF lock, but is having a tough time with the major adjustments - you can quick shift the lens to about the right focus zone, and the camera can take over from there.
In situations where you want to microadjust the focus on your own without switching to manual mode - like macro shots.
In situations where (less applicable for the DC motor of the 18-135) the lens going through it's full range of focus will generate a nice amount of noise from the screw-drive.
07-30-2012, 09:14 AM   #11
Indopunk's Avatar
Thanks for enlightening me on this. I can think of many situations in the past where the Quick Shift feature could have come in handy. Definitely something to consider. They don't sell the K30/18-135 mm WR with the white body though.
k-30, k-50, k30, kit, kx, lens, mm, pentax k30, pentax k50
K5 vs K30? CTR01 Pentax K-5 135 06-22-2014 06:26 AM
Blue K30? synapsestorm Pentax K-30 & K-50 21 07-27-2012 05:00 PM
K7 - Upgrade to K30, buy a "cheap" K5 or Wait for the K3? EstimatedEyes Pentax K-30 & K-50 13 07-18-2012 04:14 PM
First Problem with K30 LaurenOE Pentax K-30 & K-50 35 05-24-2012 01:02 AM
K-r successor: K30 LFLee Pentax News and Rumors 653 05-23-2012 11:12 AM
All times are GMT -7. The time now is 04:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
