Originally posted by Anvh DNG from the K30 even work in lgihtroom 1 and photoshop CS1 so adobe support is good.
It are the programs that dont use the camera-profile inside the DNG that need to have specific support.
I think that definitions like "Full", "Good", "Partial" or "No" DNG support of RAW rendering/editor SW can be misleading or can be a subjective impression.
If the colors are totally wrong it might be clear, but if there is a slight brightness or color difference it is difficult to check for end users.
And it can happen, that after a SW update the SW rendering result (not only color) of a specific DNG is dramatically improved.
Originally posted by rawr: So what do we have so far:
...(snip)
- Silkypix as supplied with camera
Still to come:
...(snip)
- others like dcraw, Darktable etc
I used also IDimager (which is based on dcraw) and the result (JPG preview vs rendered RAW data of DNG file) looks quite ok (DNGs are only a little bit darker).
Can you tell just from this, that DCRAW does not (or does or does fully) support K-30 DNGs?
With Silkypix Pentax version the result is very dependant on the various options of DNG or other color profiles which can be selected in Silkypix settings.
And the original K-30 JPGs always look different than the displayed DNG files with all tools.
Of course we do not know what kind of internal RAW2JPG processing is taking place in the K-30. May be such JPG to DNG comparision does not make sense?
