09-01-2013, 01:25 PM   #31
QuoteOriginally posted by arkav Quote
With the K30, it appears to me that my only option is to push the green button, which rarely yielded
a correct exposure setting on my K200D ( I admit I haven't tried it on the K30, but from what others
have said in this thread, I'm not hopeful ).
I wouldn't be so negative about that, I've made a few dozens of shots with the green button on my K30 and a manual lens and the metering was never off. Multi-Segment metering also works without problems. I can't really understand where the negative opinions come from.
09-02-2013, 05:35 AM   #32
I think it depends on which manual lens you're using.
As far as I know, Matrix metering doesn't work when doing stop down (green button) metering on manual lenses. I think it defaults to center weighted if the camera is set to Matrix metering. This might work OK on some lenses, depending on the subject being photographed.
I guess it's a shame that they do provide the ability to get DOF preview using the Raw/Fx button, but by disabling the meter while in preview, they've removed a useful function when using old lenses.
I believe that other bodies, where the DOF preview is on the ON/OFF switch don't disable the meter while preview is active. This is true for the K200D, and I believe it's true for the K7. OK, you have to program the Raw/Fx button on the K30 to get DOF preview, but why make it work differently by disabling the meter ? It seems like a deliberate attempt to discourage the use of old lenses. Or perhaps it was an oversight.
( It could probably be fixed with a FW update if enough users complained )
Cheers
button, customize, k-30, k-50, pentax k30, pentax k50
Lens unlock button missing steve917 Pentax K-5 30 12-10-2012 09:41 AM
Green button and AE-L button voyager13 Troubleshooting and Beginner Help 7 06-28-2012 12:26 PM
Green button or +/- button for meter? kidblue Pentax SLR Lens Discussion 15 07-29-2011 07:10 PM
Lens unlock button missing Tired Old Man Pentax K-5 2 06-18-2011 07:06 PM
Green button re-assign. Missing out? lavascript Pentax K-r 7 01-27-2011 10:48 AM
All times are GMT -7. The time now is 12:55 AM. | See also: NikonForums.com, part of our network of photo forums!
