Originally posted by jorgitog1 I was a K-X owner and decided to switch to a K-30. I found it to have a higher IQ but ended up throwing away more pictures than with my K-X. The autofocus was too picky and therfore slower. Also pictures had more noise than with my old K-X. I wanted my upgrade to work but unfortunately ended up returning it yesterday.
It could have been my camera but since my 30 days from B&H were expiring I decided to return it.
Maybe it is too early to come to any conclusions but the posted pictures of the K-5 look superior than the quality of pictures I was getting from the K-30.
Anybody else having such problems?
AF is improved even on K-r when compared to K-x. Same thing is with IQ, but you must take some time to finetune custom NR in order to take advantage if you shoot JPEG only.
K30 has even further improved AF, so must be some human error there in your evaluation. Maybe your lens is defective or not 100% compatibe. Some third party lens use reverse engineering and might not work properly with latest cameras.
IQ from K30 has a lot more detail and lower noise if you just look at the out-of-camerra JPEGs. If you shoot raw and process yourself you can screw up even the best raw file and end up with a noisy one.
