Originally posted by graym3546 No, you have to raise it manually.
Look for the flashing flash indicator in the view finder, if it's flashing then it is suggesting you use the flash. Push the button on the side of the flash and when you take the shot the flash will fire. On the K-x in auto flash mode the flash would pop up automatically if the camera wanted to use it. On the K-30 you have to do that manually, which begs the question why have an auto flash mode that doesn't actually automatically use the flash?
If you have the flash raised and set to auto, the camera will only fire the flash if it thinks it needs to. Not sure why they have changed it, I preferred the way the K-x was setup even though I generally had it set to manual.
I've been "yelled" at in a museum becaude my flash fired when I really didn't want it to... but in fairness, the camera couldn't possibly have know it was on top of a tripod.
Perhaps the reason the auto pop up was left out is because the programmers who wrote the firmware and the engineers who designed the pop-up mechanism decided, "...hey we think you might want to use the flash, but if you want to do it your way... go right ahead... but don't say we didn't warn you."
I have a small Panasonic P+S and it drives me crazy when the flash fires because it thinks it should... even though I'm braced up against a door frame. I've taken to forcing the flash off until such time as I turn it on myself.
