I, too, have just bought a K-30 online, and it has a remarkable amount of component-shift inside the body -- movement which a) is not affected in ANY way regardless of SR, dust removal, live view or other settings (i.e., with each of these settings in the "Off" position, the phenomenon remains) and b) is equally present when the entire camera is OFF.
To be clear: just because some amount of movement inside Pentax bodies is normal does NOT mean what mengazaa is describing is limited to that normal amount of movement. He (and I) may indeed have defective bodies, perhaps ones damaged in shipment.
The arrival of mine, for instance, reflected the typical sort of genius human behavior when packaging things for shipment: 1) put the item in the box, then 2) add (insufficient) padding atop it (vs. all around it, particularly underneath)...this would be fine if gravity acted in reverse, such that when carriers dropped or tossed packages they fell upward and hit the ceiling.
