07-06-2013, 12:34 AM   #61
Looks like the Metz 50 does not have an A-Auto setting which the Metz 58 has. You could try P-TTL/P-TTL HSS and see what happens.
07-06-2013, 07:38 AM   #62
QuoteOriginally posted by donfenix Quote
SteveB, I don't think a bounce flash EV compensation in the camera would solve the problem. From the emails I have exchanged with Metz it seems that the camera tries to control the flash power based on the distance to subject. It does this whether in bounce mode or straight ahead. Normally this feature should turn off when you tilt the flash head into a bounce mode even for a small angle. The reason is that the distance between your lens and your subject will then have nothing to do with the distance between your bounce surface and your flash (it will be completely random based on how high/reflecting your ceiling is or how far/reflecting your wall is). Older cameras like the K-x don't suffer from this because the camera doesn't communicate any distance to the flash in any mode, bounce or not. The newer K-30 should normally turn off this distance communication feature as soon as it senses the bounce mode, but it does not, which results in random exposures, at least that's how I understood it. I agree with you that the K-30 needs a bit of firmware fixing, I just don't know what's the best way to bring that problem to Pentax's attention, especially that you and I are using non-Pentax flash brands. If I could get a confirmation from another member that he/she experiences this same problem with Pentax's own AF360 or AF540, then it would be a very strong case. Metz wrote back to me that this is not the kind of problem that they could address with an update to the flash firmware (which leaves the camera firmware update as the only potentially viable solution). Metz's more advanced flash (the 58 AF-2) can allegedly get around this problem as it has its own sensor and can work without P-TTL but I'm not ready to pay $400 for that yet.
Through trial and error (or maybe dumb luck) I found my K-30 and AF360 flash work much better in P-TTL bounce mode when I use the wide angle diffuser built into the flash head. I often dial in a -1 FEC on the body and generally get good and consistent results. What seems to happen is employing the diffuser tells the flash (and camera?) to operate at full wide angle and not zoom according the distance info received from the camera.
If the Metz has a built in diffuser like the Pentax does, I suggest anyone with the flash to try it and see if it improves results.
af-1 flash, feature, flash, k-30, k-30 and metz, k-50, mecablitz 50 af-1, metz, metz mecablitz, pentax, pentax k30, pentax k50, version
For Sale - Sold: Metz mecablitz 58 AF-2 Digital Flash for Pentax Cameras mrclark321 Sold Items 4 05-24-2012 07:09 AM
For Sale - Sold: Metz Mecablitz 50 AF-1 Digital Flash tas 0425 Sold Items 8 04-10-2012 07:13 AM
Metz Mecablitz 44 AF-3 flash - opinion(s)? ajuett Flashes, Lighting, and Studio 3 05-02-2010 10:57 AM
All times are GMT -7. The time now is 01:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
