09-10-2012, 09:35 AM   #1
No lens exif data
Exif data showing everything except the type of lens used.
Kr always showed 18-135 information.
Suggestions?
09-10-2012, 09:50 AM   #2
Anvh's Avatar
Which program?
Try a free exif reader from the web, see what they find.
09-10-2012, 09:53 AM   #3
Na Horuk's Avatar
Are the lens contacts clean? Does it record other lenses?
09-10-2012, 10:09 AM   #4
Does not record either my 18-135 or 55-300.
All the other data is there, i.e. shutter speed, ISO, focal,length, etc. It just doesn't record
What lens I had on the camera at the time.
Maybe format the sd card?
09-10-2012, 10:27 AM   #5
Anvh's Avatar
Ah
Most likely your program doesnt know the lens ID.
The ID is a number so there is a library for the program that connect that number to a lens
09-10-2012, 10:27 AM   #6
Pentax camera utility saves all my exif but windows and other programs don't
09-10-2012, 10:45 AM   #7
Using iPhoto and it always recognized both lenses when used with the Kr. I dunno...technology is frustrating!
09-10-2012, 10:52 AM   #8
Anvh's Avatar
check if there is a lens ID in the exif data, that tells you enough where the problem is.
you have a great EXIF reader on the Mac it is called Preview
try it drag a jpeg or nef file on to Preview and then pull down from Tools in the menu
you will be amazed at all the info there
09-10-2012, 11:11 AM   #9
Less data there than in iPhoto.
09-10-2012, 11:47 AM   #10
Anvh's Avatar
Maybe you can throw a file online so we can check it?
09-10-2012, 12:07 PM   #11
Canada_Rockies's Avatar
They image program on your computer needs to be updated. It does not know about the combination of K-30 and those two lenses.
09-12-2012, 02:25 PM   #12
New Englander - Could be something as basic as your Exif reading programs not recognising the JPEG version...
The K-R uses v. 2.2 - and the K30 v.2.3....
With Linux, I just found that updated Digikam reads the K30's exifs - updated RawTherapee doesn't.
CLI (command-line) "exif" does read the 2.3 exifs.
Regards, Dave.
09-13-2012, 09:57 AM   #13
Thanks for responses. I will let out know how I make out.
09-13-2012, 10:17 AM   #14
Anvh's Avatar
As far as i know the exif between the two versions is the same.
09-13-2012, 01:39 PM   #15
Anvh - Quoting the Manuals:
From the K-R Manual, Page 331 - File Format > RAW (PEF/DNG), JPEG (Exif 2.21), DCF2.0 compliant.
From the K30 Manual, Page 272 - Recording Formats > RAW (DNG), JPEG (Exif 2.3), DCF2.0 compliant.
Version 2.3 was released 26th April 2010 - so software or firmware designed or released before that might not be fully compliant with it.
Regards, Dave.
data, exif, k-30, k-50, lens, lens exif, pentax k30, pentax k50
K5 and lens data in EXIF AOShep Pentax K-5 7 07-05-2011 12:39 AM
DA Lens data and EXIF GeneV Pentax SLR Lens Discussion 9 04-21-2010 07:29 AM
EXIF data on 50mm lens deludel Pentax SLR Lens Discussion 5 06-04-2009 01:30 PM
Pentax Lens Tagsin EXIF Data Wheatfield Pentax DSLR Discussion 5 10-17-2008 12:30 PM
Lens Exif Data and DxO dddphoto Digital Processing, Software, and Printing 17 02-17-2008 03:16 AM
All times are GMT -7. The time now is 03:47 AM. | See also: NikonForums.com, part of our network of photo forums!
