09-13-2012, 07:22 PM   #1
K30 Manual ISO setings
Third time out with the K30 and it was very cloudy at the cross country meet. Wanted to change ISO but it would only let me go 800, 1600, 3200. Is there any way to choose 1200 or 2000?
I looked in the manual and could not find anything that led me to believe one could have that much control. TAv mode does choose those ISO settings, but it would go higher than I wanted.
09-13-2012, 07:30 PM   #2
There's a custom function setting that controls EV step size. You need to set it to 1/3 rather than 1/2 stops in order to be able to access intermediate ISO values (and apertures).
09-14-2012, 12:52 AM   #3
jup
Custom Settings 1 -> 2. Sensitivity Steps. This defaults to 1 (1 EV step), which only allows you to set 100, 200, 400 and so on. You want to set it to 2 (As EV Steps). Then it will go in increments of 1/2 or 1/3 EV, depending on custom setting 1, Sensitivity Step.
09-16-2012, 04:19 AM   #4
poison's Avatar
thnx
09-17-2012, 04:24 PM   #5
Thanks a bunch. After I posted this thread I went back thru the book and found it. So far lovin the camera and 18-135, much better than the Kr in my book.
09-21-2012, 01:23 AM   #6
I have another question that is sort of related to this:
I'm kind of control freak, so most of the time I shoot in manual mode.
As most of you would guess, I use green button to let camera recalculate settings automatically, rear wheel for time setting and front wheel for aperture setting. BUT when I also use manual AF point selection (which is key feature for me), I can not easily change ISO setting without going to menu and turning the manual AF point selection off, then setting ISO, then back to menu and setting it back on. Alternatively I can set ISO from INFO screen, but that isn't much shorter. Another alternative is to set ISO to automatic mode and set the boundaries, but I don't like that very much.
Note: This whole situation occurs because the manual AF point selection takes all of the four-way pad's buttons.
I was trying to find the solution in user manual, but I found nothing about alternative ways to get to ISO setting, or ideally quick way to toggle manual AF selection by binding it to some button.
So my question is: Is it me and my lack of experience, or there is really no way around this?
09-21-2012, 02:06 AM - 1 Like   #7
jup
QuoteOriginally posted by Snapi Quote
When you're in Select focus point mode, you can switch off focus point selection by pushing and holding OK button for 1 sec. Page 103 in the manual.
Then you can use 4 way controller to change settings and your focus point stays at the last selected position. To be able to change it again, just press ok button (no need to hold it this time).
Alternatively, you can assign RAW/Fx button to AF active area. This allows you to turn focus point selection on/off with RAW/Fx button and also use wheels to change focus point while it's on. But I found for me, ok button works just fine, even though there's 1 sec wait.
09-21-2012, 02:49 AM   #8
Thank you jup, that feature with OK button is exactly what I was looking for! You just made my day
09-21-2012, 06:42 AM   #9
I love this forum! I never checked out that Sensitivity Steps option. I just got new ISO options now
iso, k-30, k-50, k30, pentax k30, pentax k50
Why my K30 cannot switch to manual mode? sjsj94 Pentax K-30 & K-50 18 09-23-2012 06:38 AM
AE lock ignored when adjusting ISO in manual mode drougge Pentax K-5 14 10-29-2011 05:08 PM
How to change ISO in Manual Mode closekd Pentax K-r 2 07-04-2011 09:26 AM
ISO in Manual Mode campdog Pentax DSLR Discussion 4 11-24-2009 12:29 PM
ISO in manual mode dustartist Pentax DSLR Discussion 16 03-21-2008 06:27 PM
All times are GMT -7. The time now is 06:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
