09-16-2012, 08:45 PM   #1
New K30 seems to have high amounts of noise?
Hello.. I'm new to Pentax. Just purchased K30. Really love the camera - how it feels and features of coarse but I'm having issues w/ what appears to me to have very high amounts of noise - even at ISO 400 or even 800. 3200 to me is unacceptable. Can anyone take a quick look at these snaps (using cheap kit lens, this shouldn't have anything to do w/ noise) and let me know if this is normal or am I doing something wrong? Thanks
I've added raw/converted to jpeg w/ no editing for both old canon 30d and new K30.
http://jtalbot.smugmug.com/Other/Pentax-Test/i-2tZZ34Q/0/XL/canon-30d-9162012-XL.jpg
09-16-2012, 08:53 PM   #2
Sorry. Wrong embedded link. Here is link comparing both files: Move your mouse over pic and you can view original. Thanks again.
Pentax Test - jtalbot's Photos
09-16-2012, 08:55 PM   #3
hcarvalhoalves's Avatar
EDIT: You forgot to include the K30 sample, but I found it on your smugmug profile.
Canon 30D
http://jtalbot.smugmug.com/Other/Pentax-Test/25413954_np2dZg#!i=2091629094&k=2tZZ34Q&lb=1&s=A
Pentax K30
http://jtalbot.smugmug.com/Other/Pentax-Test/25413954_np2dZg#!i=2091631446&k=9FKBBfK
The problem is, the colors are totally off. Each camera dealt with the white balance differently (the Canon didn't attempted to correct for tungsten), so you can see more artifacts on the K30 because of the color cast. The K30 is underexposed too (f/5.6 instead of f/4, both shot at 1/20 ISO 1600). I guess you shot the Canon first, then tried to dial the same settings on K30 in M mode, but the kit lens only goes to f/5.6?
Redo the test setting both for the correct AWB (either tungsten or daylight) and same aperture. Noise should be equivalent.
09-16-2012, 08:56 PM   #4
Your Pentax pic is underexposed by a stop, that's why it seems worse. The less light there is, the more of the noise you will see. So, if you re-shot the test at F4 rather than F5.6, the results should once again be acceptable.
09-17-2012, 05:26 AM   #5
georgecape's Avatar
ISO 8000 f3.2 1/25 only some cropping but I'am sure it'll cleanup with a bit of PP'ing.
amounts, k-30, k-50, k30, noise, pentax k30, pentax k50
How to elminate K7 high iso noise alexshen8 Pentax DSLR Discussion 13 03-07-2011 10:23 PM
The K7 and High ISO noise Workingdog Pentax DSLR Discussion 49 11-24-2010 05:14 AM
K-5 and High ISO Noise software David Pentax K-5 7 11-24-2010 01:16 AM
High Noise at Low ISO? JGB Troubleshooting and Beginner Help 19 11-11-2010 07:39 PM
K-x high-ISO noise reduction: use it or do it in PP instead? richardm Troubleshooting and Beginner Help 5 10-28-2010 08:45 AM
All times are GMT -7. The time now is 07:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
