09-19-2012, 01:18 AM   #1
How's K-30 for metering with manual lenses?
Hi, I'm a K-r user. We all know that Pentax DSLRs can meter manual lenses (K/M) with the green button stopped down. But from practical experience, it's never totally accurate. I'm still trying understand it's metering behaviour. While it's within the ballpark, I do wish it could be accurate without having to do some trial and error. That's the K-r, so how about the K-30? Is there any improvement in this application?
If the exposure with manual lens is a big improvement from the K-r, it will be one of my deciding factor to upgrade
09-19-2012, 01:32 AM   #2
The inaccuracy is down to the focusing screen more than anything, since the K-30 has a similar type of screen that was designed to give the brightest possible image, there isn't much room for improvement in stop down metering. I have heard that changing the focusing screen to a cut down Canon Ee-S screen will significantly improve stop down metering because it is a more linear design. You can get a screen already cut from focusingscreen.com, you'll have to make up your mind about upgrading beforehand, since the K-r and K-30 take different screens.
09-19-2012, 01:47 AM   #3
paulusje's Avatar
QuoteOriginally posted by elliott Quote
I have this screen (on my K-5) and I can confirm that metering is perfect now.
Highly recommended.
09-19-2012, 02:07 AM   #4
Thanks for the reply. Now that you mentioned it, I can recall some non linearities in the metering pattern trend. In bright conditions, it overexposes while in low light, it underexposes. The K-30, having a pentaprism and exchangable screens does makes it easier to change to a split focus screen on the fly, which is very appealing to me. The K-r's screen while it's actually removable, it's not an easy task and having a hollow pentamirror, dirt can easily land deep in the mirrors during the process.
09-19-2012, 02:24 AM   #5
paulusje's Avatar
QuoteOriginally posted by weijen Quote
The stock screen has a non linearity where it would under expose with large apertures and over expose for smaller apertures:
https://www.pentaxforums.com/forums/pentax-k-5/142241-best-screen-ever-manual...ml#post1485798
improvement, k-30, k-50, k-r, pentax k30, pentax k50
Manual Metering on Pentax DSLRs with Manual and Automatic Lenses Adam Pentax DSLR and Camera Articles 20 01-06-2016 03:38 AM
Pentax 645N: metering with manual lenses psychoanalyst Troubleshooting and Beginner Help 3 07-14-2011 10:33 AM
K-7 LV metering with manual lenses Jadran Pentax DSLR Discussion 6 01-12-2010 12:57 PM
Metering with Manual lenses.. arbib Pentax SLR Lens Discussion 21 01-03-2010 10:22 PM
K10D, manual lenses, and metering vinzer Pentax DSLR Discussion 40 06-30-2007 07:54 AM
All times are GMT -7. The time now is 05:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
