10-07-2012, 04:57 AM   #1
Dachiko's Avatar
K-30 sd-card compartment door defect
I just uploaded a
of defect of my k-30. This defect was from the start, but it takes time to discover how to recreate it. Can you test your k-30 on this subject?
10-07-2012, 06:21 AM   #2
Dodgy microswitch. I doubt it's anything more than bad luck on this one unit unless there's a batch problem. It happens with switches. I feel sorry for manufacturers like Pentax who have to buy in components as it's Pentax who get the bad publicity when a component fails, not the component suppliers. A single drip of switch cleaner may be able to work its way inside and fix it though, but that's your call; I wouldn't do it if there's any chance of fluid getting further inside the camera.
10-07-2012, 09:50 AM   #3
I had a similar problem but it was the sd card that was faulty and not the camera. It was quite an old 1GB card.
Opening and closing the door resets communication with the card (even when the camera is switched off) so it may well have nothing to do with the door or switch not making proper contact but instead the SD card that is messed up and needs a reset.
Before doing anything to the camera try different SD cards.
10-07-2012, 10:53 AM   #4
Dachiko's Avatar
Even wo card i have a same experiense.
10-07-2012, 09:24 PM   #5
Hoggy's Avatar
I'm with Steve - It's probably a bad microswitch in the card door. I tried pushing on the card door on mine and nothing happened.
Of course, you could try a different card, but most likely it must be that switch since it does that without a card in there.
The good news is that there's a standard 1-year warranty on it, but you can get a 2-year extension (total 3-years) for $25 from Adorama. To me it was a no brainer. Plus, you get 1 free checkup/cleaning.
defect, k-30, k-50, pentax k30, pentax k50
Battery Compartment no sealing? misbehave Pentax K-30 & K-50 5 08-05-2012 01:39 AM
K20D won't turn on due to card door (?) mirocal Pentax DSLR Discussion 3 02-09-2012 01:37 PM
Pentax MV Battery Compartment... eniceeleven Pentax Film SLR Discussion 2 08-23-2011 02:55 PM
Loose flash battery compartment door (AF-280T) iht Troubleshooting and Beginner Help 5 02-01-2010 07:48 AM
Problems Opening SD card door pentax07 Pentax DSLR Discussion 2 09-04-2007 10:28 PM
All times are GMT -7. The time now is 04:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
