Originally posted by JinDesu Tav isn't new, it was on the k-5 also
And the K10D, K20D and K-7.
In TAv mode, I set ISO to the range I want to stay within. If the camera warns me that my max ISO is too low, I can decide whether to boost ISO, or back off the aperture or shutter speed.
I don't see the point of shooting at a lower ISO and bumping up in post, there is no advantage for noise. Boosting exposure in post will also boost the noise. If you use the camera settings for noise reduction*, you will end up worse off, because the image will have less noise reduction applied at a lower ISO setting.
* I shoot raw, but I use the camera settings for noise reduction (they are imported by DCU4). The camera does a good job if NR is set to one of the lower settings. If I need more NR, I use Noiseware.
