10-19-2012, 02:27 AM   #16
Given this is all new kit, the 35mm DA f2.4 would be ideal for you, I would think, and it is not so much of an investment that you have to worry about resale. ISO1600 is completely usable on the K30, 3200 is also fine, and 6400 at a stretch. Therefore you have a lot of sensitivity to play with, and therefore a faster lens is not so required (as they are expensive!)
If you did decide to use a manual lens, you could always use the catch-focus mode on the K30, whereby the camera monitors the focus, and releases the shutter when it detects the photo comes into focus. This way, you could pickup a 35mm autofocus, and a cheap 50mm f1.4/f1.7, and then spend on an AF 50mm if you think its worthwhile (the sigma f1.4 50mm is well regarded for portraits, and is the current subject of my LBA!)
10-19-2012, 04:59 AM   #17
QuoteOriginally posted by ihasa Quote
But yes, any sort of flash is probably a bad idea for the specific type of shots the OP is talking about... Although babies are surprisingly unfazed by flash, I've found...
Newborns have their eyes closed all the time anyway.
Bounce flash in a white-walled hospital room will work really well.
Regards,
--Anders.
10-24-2012, 03:30 PM   #18
msatlas's Avatar
I really liked the DA 35/2.4 but wanted a little more background blur plus a bit more light gathering ability, so got an FA 35/2. These lenses have very similar optical designs, but the DA controls fringing a little better. The FA's not bad at all in this regard, just you have to keep an eye out in situations where you have a mostly-dark room with light source(s) in the frame.
11-07-2012, 01:50 AM   #19
Well, jus to let you know that I just did an order for a Da55 1.4
Let me have my hands on it and I'll get back t you telling how it it
Zorza
50mm, k-30, k-50, lens, pentax k30, pentax k50
Bit the bullet K30, Lens? northmole Troubleshooting and Beginner Help 12 08-31-2012 08:30 PM
Which lens for K30 Salacakli Pentax K-30 & K-50 15 08-13-2012 03:21 PM
Use of lens with K30 synapsestorm Pentax K-30 & K-50 8 08-12-2012 12:04 AM
K30 Lens protection synapsestorm Pentax K-30 & K-50 5 08-07-2012 08:24 AM
All times are GMT -7. The time now is 12:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
