10-22-2012, 03:25 AM   #1
Catch focus... Anyone know how it works?
Was trying to get this to work last night; couldn't for the life of me with any success though - despite what focus mode, LV, AFC/AFS etc
Anyone managed it and if so any ideas on how I can get it to work?
10-22-2012, 05:40 AM   #2
I wonder same in my K5...
10-22-2012, 05:52 AM   #3
mattt's Avatar
After making the necessary menu setting changes, the AF / M switch must be set to AF. I have never tried it in LV, just AF-S.
10-22-2012, 05:55 AM   #4
D0n
Banned
you need an manual focus lens or to tape over the contacts on an af lens... you set it up in the menu system to turn on the feature... then you set the body to auto focus and focus manually... you press and hold the shutter or use a cable release and the camera will not fire until the af sensor locks onto something... meaning your subject moves into focus or you move the camera until something is in focus..
10-22-2012, 06:25 AM   #5
Ah so I need a manual focus lens not a AF lens with the camera set to M. That's a shame!
10-22-2012, 06:30 AM - 1 Like   #6
QuoteOriginally posted by mattt Quote
mattt, does your lens have a switch to put it into manual focus mode? The lens must be set to M and the body must be set to AF-S. Without that, you have to resort to hacking it with tape on the contacts as also mentioned in the thread.
10-22-2012, 06:37 AM   #7
QuoteOriginally posted by Pheo Quote
Your A 50/1.7 should work, Also, Pentax AF lenses like the DA*300/4 with an AF/MF switch (when MF is selected) should work, too.
Cheers... M
10-22-2012, 07:04 AM   #8
Na Horuk's Avatar
Ok, here is the whole process:
First set your camera to AF.S or AF.A (so.. not AF.C- You may not be able to change this with a certain lens mounted, so make sure you change this ahead of time). Then go to the menu and turn on catch in focus. Now set the camera button near the lens mount to AF (not M - manual). Mount your lens. Set the lens to Manual. Some lenses are always manual (like the old M series) so you don't have to do anything there. Some lenses are never manual, these cannot use CiF (at least to my knowledge). Now you can use CIF.
CiF works in a simple way. The shutter must be pressed. When the camera notices that something is "in focus" (as in, the large center focus point detects something being in-focus) it will take a shot. You can use this by placing the camera and have something enter the focusing zone or you can simply hold the shutter button and focus manually.
You can use it in conjunction with burst mode and the camera will take many photos as long as you hold the shutter button.
Also read this:
The Focus-trapper: Trap focus
And if you are using a manual lens, this can help you in general:
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
Some lenses with a completely plastic mount with no contacts or without a "manual" switch (DA lenses) or with a narrow lens mount (Russian m42 lenses with non-flanged adapter) will not trigger CiF. You can improvise with those and modify them in some way, though I don't know any details on this.
10-22-2012, 07:39 AM   #9
mattt's Avatar
QuoteOriginally posted by IchabodCrane Quote
I only use CIF with manual glass
10-22-2012, 08:18 AM   #10
Also read this:
Na Horuk, my K-30 manual says AF.A must be disabled for CIF to work.
10-22-2012, 03:02 PM   #11
Na Horuk's Avatar
Really? On the K-r I'm pretty sure AF.A in the info menu has to be enabled (or AF.S), the AF switch on the camera has to be turned on, and the lens has to be manual.
I just tested with my K-r and AF.A works. Maybe its different from camera to camera. The problem with the K-r is that you cannot change AF modes with a manual lens mounted, so if you have the wrong mode, then you have to change lenses to change it.
10-22-2012, 04:38 PM   #12
Sagitta's Avatar
Once I figured CiF out, it became one of my favorite modes to shoot in with my old manual lenses. If you have lenses that will allow you to use it, I highly recommend figuring the technique out. It works especially well when you have a lens with a razor thing depth of field.
10-23-2012, 04:00 PM   #13
Just a shame I cannot use it with a normal lens in manual focus mode, for lower light photography / speed etc.
k-30, k-50, pentax k30, pentax k50
How to Use Catch In Focus reivax Pentax K-r 7 04-21-2013 09:14 AM
catch in focus jennverr Pentax DSLR Discussion 20 04-07-2012 09:08 AM
catch focus in K-r sany Pentax K-r 14 06-12-2011 06:15 PM
Catch in Focus mand Pentax DSLR Discussion 18 02-25-2011 04:38 PM
Catch in focus conundrum Transit Pentax DSLR Discussion 22 10-23-2010 10:46 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
