Closed Thread
11-13-2012, 09:17 AM   #1
the damndest thing at 5.6
Last week i bought a Tamron 17-50 for my new k30.
Did some test shots at 17,24,35 and 50mm. Aperture 4.0 was what you would expect from this lens. 5.6 was blurry. (i know this lens quite well from my canon years)
I thought maybe the lens was bugged. Got me another one.
Same thing. 5,6 looked like out of focus.
Then I a third TAMRON. Again 5.6 really blurry.
Must be the camera right?
11-13-2012, 09:19 AM   #2
Post some examples, it is impossible to tell without seeing it.
11-13-2012, 09:34 AM   #3
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by mckracken Quote
Not necessarily. The Tamron 24-75 that I had would focus or not depending on, well, I never did figure out what variables affected it; zoom position, aperture, Moon in the seventh house, Jupiter aligned with mars, whatever. It was a known phenomenon with the 24-75 and I have come across a few references of similar issues with the 17-50 Tamron, so it may not be an issue with the camera.
11-13-2012, 09:52 AM   #4
Huh? But i bought a lens that says Tamron 17-50mm for Pentax?
Am i missing something? I tested 3 lenses. This is unbelievable.
Well, tomorrow im installing firmware 1.01. Wish me luck. (samples tomorrow)
11-13-2012, 10:07 AM   #5
Senior Moderator
Parallax's Avatar
I think it's unlikely that it's the camera. The camera isn't doing anything differently at f4.0 than at f:5.6. By f8.0 depth of field is sufficient to compensate for any focus shift characteristics of the lens.
diglloyd - Focus - Focus Shift and Spherical Aberration
11-13-2012, 10:08 AM   #6
Na Horuk's Avatar
Did you try focusing regularly, with PD AF, and also with live view (CD AF)? Using a tripod, defocusing manually between tests on a fixed subject. I doubt its a focusing problem, because the camera always uses AF with the lens wide open and then only stops down when taking the shot. So the problem might just be with the lens itself, but this is a popular lens so maybe someone who uses it a lot can chime in.
11-13-2012, 10:11 AM   #7
So if you focus, then turn off AF so you don't refocus between shots and take the exact same shot with f4 and f5.6, then f5.6 is blurrier? If you set it on manual focus and 5.6, if you hold down the optical preview and focus (so that you are focusing with the lens stopped down to 5.6), can you get a sharp shot then? (i.e. is a focus shift occuring?)
11-13-2012, 11:08 AM   #8
I have a Tamron 17-50, and it works fine on my K200D, K-x and K-5. I doubt it would suddenly work erratically on the K-30.
There are duds lenses out there, of course, but the issue you are describing is not one I've heard of with the Tamron. f5.6 is normally good at all focal lengths.
You probably need to revisit your testing technique to make sure you are doing everything precisely, and aren't seeing for example ordinary motion blur. You also need to say whether you were using AF or manually focussing. If you are just testing the lens optics, you don't need to use AF.
11-13-2012, 01:54 PM   #9
been messing around real quick with liveview focus and viewfinder focus.
seems that the liveview AF works fine. (manual too)
the regular AF is a lot worse and almost unuseable.
11-13-2012, 02:00 PM   #10
JinDesu's Avatar
Well that's just.. weird. If it focuses at F2.8, it should focus at any aperture. Your camera checks focus at the widest aperture, and stops down after. So if there is nothing inherently wrong with the lens at F5.6 (from CDAF and manual focusing), then I don't know what to say..
11-13-2012, 02:52 PM   #11
been messing around real quick with liveview focus and viewfinder focus. seems that the liveview AF works fine. (manual too)
Please describe the issue or problem more clearly.
You seem to be saying at f5.6, at all focal lengths, you get blurry images, but only with regular AF. However, when manually focussing, and when using liveview focus, your images are not blurry at f5.6.
This seemingly rules out any optical problems with the lens, or any problems with the AF mechanism in the lens too.
So the remaining things to look into are (a) the regular phase-detection 'viewfinder' AF and/or (b) your testing technique.
What settings have you been using for your viewfinder AF? And are you using anything like a UV filter on the lens?
11-13-2012, 03:08 PM   #12
I will post back tomorrow, the hour is getting late.
thank you all so far for your interest in my problem.
11-14-2012, 06:20 AM   #13
Expanded area af: off and on
Af active area selectable, center selected
af assist light on.
Shake RD on and off
I tried a lot of variations but the problem persists:
at 5.0 sharp, 5,6 blurry, 6.3 sharp again.
11-14-2012, 06:52 AM   #14
altopiet's Avatar
Have you tested with any other lenses?
11-14-2012, 06:53 AM   #15
(sorry cant edit my posts yet)
after another batch of tests, i did not get a sharp pic at 5.6 and above....
Closed Thread
blurry, k-30, k-50, lens, pentax k30, pentax k50, tamron
For Sale - Sold: Tokina AT-X 80-400mm f/4.5-5.6 hiep2503 Sold Items 5 03-24-2012 08:54 PM
For Sale - Sold: Tokina AF 24-200mm f3.5-5.6 SD AT-X 242AF *LN* cheekygeek Sold Items 3 12-10-2011 01:38 PM
For Sale - Sold: Tokina AT-X II AF 80-400mm f/4.5-5.6 zoom for PENTAX mmzymxf Sold Items 3 08-01-2011 08:19 PM
For Sale - Sold: Tokina AT-X AF 80-400mm f/4.5-5.6 (near mint) (Worldwide) JP_Seattle Sold Items 4 01-09-2011 02:06 PM
All times are GMT -7. The time now is 01:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
