11-14-2012, 10:12 AM   #1
-10 Fine adjustment not enough.
Is there a way to adjust K30/lens beyond the -10/+10? (I need about -14 for a Tammy) Thanks!
11-14-2012, 11:17 AM   #2
cali92rs's Avatar
QuoteOriginally posted by Kevwaly Quote
Are you positive that your testing technique is fine or that your lens is not broken?
That is a lot of adjustment.
11-14-2012, 12:18 PM   #3
Yes, believe testing is true. New lens - (Tamron 28-75). All other lenses needed small adjustment, this one lens was much sharper at -10 but still front focusing a bit. I may have to send it back for new one.
11-14-2012, 12:25 PM   #4
audiobomber's Avatar
If it's a new lens, send it back. I've done that with the last three lenses I bought, and it's worked out well for me in each case. Two of these were within the camera's range to compensate, but why put up with a miscalibrated lens? Get it fixed under warranty, that's my strategy.
11-15-2012, 04:58 AM   #5
New in the pentax world, and owner of a k-30 and a 55mm da* 1.4.
How can I tell it the lens is well calibrated or if it needs adjustmment??
Thanks
Zorza
11-15-2012, 05:47 AM   #6
I use this chart: Nikon D70 Focus Chart
11-15-2012, 03:19 PM   #7
FruitLooPs's Avatar
Also these ones:
http://www.k10dbook.com/newchart.pdf
PENTAX DSLRs: Front or Back Focusing Problems? Free test (Lens Alignment) charts for Pentax, Nikon, Canon, Sony, Olympus.
I had a tamron 17-50mm F2.8 that needed way more than the K-30 could adjust, had to send it in for adjustment as it was secondhand. Still not right sadly, but much better.
11-16-2012, 09:15 AM   #8
you have the same problem as me: (its NOT the lens)
see thread the damndest thing at 5.6
11-16-2012, 10:33 AM   #9
Hmmmmmmm. Thanks for the input. I read the whole thread.
11-16-2012, 11:01 AM   #10
kevwaly, is AF fine up to aperture 5.0?
11-16-2012, 12:52 PM   #11
Will do more testing tomorrow and get back to you. (Working til late.) Will check AF throughout apertures on both Tamron 28-75 and Pentax 55-300.
11-16-2012, 04:35 PM   #12
Re: AF problems Tamron 17-50: Pentax SLR Talk Forum: Digital Photography Review
11-17-2012, 08:36 AM   #13
I've just done some experiments and maybe I figured out what could be going on.
I've just made a post on DPreview which might be of interest.
To cut the story short I have a Tamron 10-24 which behaves similar to what is described but I have determined that it is actually working properly. In other words the apparent weird behaviour is actually correct and most importantly results in correctly focused images.
Of course I've no idea whether that is also the case for the 18-50 as I don;t have one of those.
11-17-2012, 11:09 AM   #14
how can the image be correctly focused if it is out of focus?
you kinda lost me there...
11-17-2012, 05:27 PM   #15
QuoteOriginally posted by mckracken Quote
All the posts about the 17-50 that you link to on DPR (and the rest of the links all over Google for Tamron AF issues for Canon, Nikon etc bodies) suggest that is indeed the lens, not the camera.
k-30, k-50, pentax k30, pentax k50
AF Fine adjustment OrchidJulie Pentax K-r 23 11-05-2012 03:47 PM
AF fine adjustment marinb Pentax K-5 15 02-19-2012 09:41 PM
AF Fine Adjustment, focus correction, AF micro adj., AF fine tuning annajonna Pentax K-5 13 11-19-2011 11:32 PM
AF Fine Adjustment phoenixrose Troubleshooting and Beginner Help 2 07-30-2011 08:05 AM
AF adjustment not enough?? ueda_masaki Pentax K-5 11 12-08-2010 05:33 PM
All times are GMT -7. The time now is 08:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
