11-29-2012, 08:08 PM   #1
K-30 "AWB in Tungsten Light" setting does not work
I tried to take some pictures in incandescent light and found that there is no difference between "1" or "2" value for "AWB in Tungsten Light" (Last group of menu items, C-2 #11). It is supposed to apply "1. Subtle Correction" or "2. Strong Correction". What am I missing? Can some one please verify this?
Edit: The menu option is for "Auto" white balancing when the camera detects incandescent light. I was trying to use manually selected incandescent white balancing to produce warmer results similar to K100D.
11-29-2012, 08:43 PM   #2
Can you post some samples? It could be that no correction is needed.
11-29-2012, 09:05 PM   #3
The original post was partly my mistake. The menu option is for "Auto" white balance when it detects incandescent light. Not when you set the camera for incandescent white balancing. (I think).
An old K100D did produce a much warmer color even after applying WB for tungsten.
Attaching two images one from K100D Tungsten light White Balance. Second image is using K30 again with Tungsten light White balance.
I was trying to produce image similar to K100D in K30.
PENTAX K100D  Photo
PENTAX K-30  Photo
11-29-2012, 09:16 PM   #4
JinDesu's Avatar
So... you want a warmer white balance ever after tungsten? I know my k-x is really cool when applying tungsten white balance, so I'm not sure there is such an option.
11-29-2012, 09:30 PM - 1 Like   #5
Ole
Ole's Avatar
You can fine tune the white balance settings, page 144 in the manual. You can make the tungsten setting colder or warmer as you please.
11-29-2012, 09:38 PM   #6
QuoteOriginally posted by Ole Quote
Excellent tip! I played with that a little, I should be able to make the result similar to that of K100D.
Thank you!!
(Wow! Pentax, you rock!!)
11-30-2012, 01:36 AM   #7
The 'extra strength' setting of 2 for AWB definitely works on my K-30, giving the best natural colours I've seen yet from a range of cameras and phone cameras used in my mainly low-energy bulb (1 bedroom low wattage tungsten) lit house and it also seems to be safe to leave the K-30 at that setting for normal daylight shots, although I haven't judged it thoroughly so far but nothing has looked 'off'. The default setting of 1 seems warm enough indoors under artificial light if that's what's desired. I have one issue though, yet to be investigated properly, but AWB2 didn't seem to reduce excessive warmth on a couple of old M lenses, I had to use the Tungsten setting for those.
k-30, k-50, light, menu, pentax k30, pentax k50, tungsten
People K-30 - 1st "Shoot" - "A Girl & Her Bike" Julie Post Your Photos! 8 09-01-2012 09:38 AM
k1000 in "not-so-low light" mfenoglio Pentax Film SLR Discussion 7 08-01-2012 08:29 PM
"A" apeture setting doesn't work miltona580 Pentax SLR Lens Discussion 7 09-22-2011 08:31 PM
Reviews really missed the mark on Kr AWB in tungsten light LRB21 Pentax K-r 3 09-06-2011 03:12 PM
FA 50mm f1.4 not engaging in "A" setting thehabit Troubleshooting and Beginner Help 7 06-02-2011 11:53 PM
All times are GMT -7. The time now is 11:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
