A very quick and easy test to determine whether the camera is focusing correctly is this:
Using the optical viewfinder the camera uses Phase Detect AF, but if you use liveview it will use Contrast Dectect AF (just as a point and shoot does). These two methods are entirely different, but all things being equal should both give you an image of the same sharpness.
1: choose an object that is on its own, somewhere easy to focus accurately on like a table - a basic object that has some detail is good.
2: put the camera something solid like a tripod pointing directly at the object, on AV and central AF point, focus on object and take photo
3: put your hand in front of the camera and half press the shutter to let the lens unfocus
4: engage the live view mode, ensure you also have central area AF and the same aperture number, take another photo
compare the two, you can try different apertures. Obviously as you stop down the lens (F8 etc) you will see sharpness increase. You want to keep all variables the same like lighting etc.
You could use the same rig to play around with the aforementioned jpg micro-sharpness adjustments too.
If the liveview image is noticably sharper it is possible the optical/PDAF focus mechanism needs adjustment with in-camera settings. You can investigate this further with search, and find dedicated focus charts etc at various places. As stated though, that kit lens is only sharp in very select situations good light stopped down etc.
