Originally posted by SteveB Bit police alert :- 2 bits difference is always less than 4 bits difference
Not true, because the increase is logarithmic. Think about earthquakes. Magnitude 7 is much worse than magnitude 4. But magnitude 9 is a disaster that will reverberate around the world, literally in some cases.
That said, the
perceptible difference isn't necessarily that great (you view the image on something limited to 8-bits in most cases). The advantage is in signal-to-noise ratio. 14-bits is significantly more information in the raw file.
