02-19-2013, 07:54 AM   #1
AF in low light
Hello,
It appears that my K-30 focuses in low light much better then my old k100d.
K30 seems to focus quick to my needs the only problem I have, is that photos comes out fairly blurry even when the flash is used.
I did few tests at home with only 1 standing light in a room and many photos are still a bit blurry (when taken with 180 shutter speed)
Whats you're experience in low light?
Thanks
02-19-2013, 08:20 AM   #2
enoeske's Avatar
Its hard to say and would be a complete guess without seeing one of the offending photos (with intact exif data). It could be a number of things.
02-19-2013, 09:14 AM   #3
hcc
hcc's Avatar
QuoteOriginally posted by m112 Quote
Please define low light. In very low light, no AF will work even with a fast lens. This is an issue with most camera. Instead you need to use MF.
My 5 cents...
02-19-2013, 12:14 PM   #4
Well, in an average room with 1 low energy 11 watt table lamp with a shade I would say my K-30+35/2.4 can produce repeatedly sharp enough shots, better than several other cameras I've tried in the same circumstances without flash. However, in low light there's focal length (FL), shutter speed, aperture, lens quality, ISO, shake, noise, noise reduction effects all at play and liable to detract from optimum sharpness if poorly chosen. I'm having to use ISO 5000+ in the lighting I mentioned to get 1/160s at f2.4.
A shutter speed of 1/FL should be easily capable of sharp shots even without SR on, I won't go below 1/8s using 35mm, preferably 1/13s as that's pretty much guaranteed to be sharp. As you've had problems even when using flash, that does tend to rule out motion blur though, so perhaps it is a focusing problem or you're using a really high ISO with high noise reduction which will soften images.
02-21-2013, 07:57 AM   #5
I was testing the camera with just one energy saving light in a room.
The camera was focusing quickly - I had green dot - however when the photo was taken WITH flash the result was still fairly blurry.
This also applies to Children scene where shutter is about 180
02-21-2013, 11:42 AM   #6
Was anything in focus? For instance, it's quite easy to lock onto the background when trying to grab a moving target. I tried the Kids Scene mode (1st time!) and couldn't find any issues but there again I haven't got any children running around.
02-21-2013, 11:46 AM   #7
enoeske's Avatar
once again, Its hard to say and would be a complete guess without seeing one of the offending photos (with intact exif data). It could be a number of things.
03-04-2013, 11:13 PM   #8
Ken T's Avatar
QuoteOriginally posted by enoeske Quote
Agree
k-30, k-50, light, pentax k30, pentax k50, photos
Would you rather take the best low-light AF APS-C or another lousy AF FF? LeDave Pentax DSLR Discussion 23 09-10-2012 11:54 PM
AF in low light disco_owner General Talk 2 05-16-2012 06:12 PM
K-5 and continuous AF mode in low light? enoxatnep Pentax K-5 6 11-29-2010 06:11 AM
AF in low light of 31 Limited candgpics Pentax SLR Lens Discussion 10 12-30-2009 07:15 PM
AF in low light situations. AM|Photography Pentax DSLR Discussion 2 06-24-2009 01:59 PM
All times are GMT -7. The time now is 04:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
