05-15-2014, 08:06 AM   #76
Pewter's Avatar
Lanparte have a product that is almost there...
#2. The solution I am looking for is 95% solved -- see this product for example by Lanparte, who market something quite close to my ideal solution but only for Canon and Nikon cameras -- lanparte portable battery for camera.
Sadly, the Lanparte manufacturers do not market a Pentax-compatible dummy battery, the PB600 product seems a bit underpowered to me coz 10,000mHa should be the minimum, and the PB600 product cannot be dual purposed to charge other devices. Its close though.
05-15-2014, 10:23 AM   #77
Pewter's Avatar
Proposed 9hr Still/Video portable battery power solution for K30, K50, Kr, K2
Following up on my previous posts below, think I can now put together a workable solution using reasonably priced off-the-shelf components than can be replaced easily enough in case lost or damaged and you would still enjoy service/warranty unlike a DIY project. It would come in three parts (not counting your camera) as follows:
1 -- DC Coupler for Pentax ie. a dummy battery with power input cable
2 -- Flexible power cable for connecting the DC Coupler to your external power supply. Usually you can buy an AC power plug, cable connecter and DC coupler as a kit/bundle. Although I am interested mainly in unplugged portable power & the AC plug would come in very handily when working indoors for example your home studio
3 -- And finally your portable rechargable external powerpack with switchable 9 to 6 volts output plus USB sockets for charging your mobile devices
And how this would work is you plug part 1 into your K-30 battery compartment, leaving the power input cable dangling through the special sealed slot purposely left by Pentax, connect the far end of Part 2 to your battery cable and connect the near end to the power supply outputs of your portable powerpack part 3.
1
B&H kit sold here -- Pentax K-AC128 AC Adapter Kit for K-30 Digital Cameras 38823 B&H
2
A flexible power supply cable on Amazon by Lanparte Amazon.com: New Lanparte LP-E8 Camera Power Coupler DC Dummy Battery Pack For 550D 600D 650D: Computers & Accessories
3
The EZOPower Black 3 -Port kit on Amazon here Amazon.com: EZOPower Black 3 -Port Ultra High-capacity Portable External Rechargable Backup Battery Pack -10000mAh (2A/2A) for iPhone, iPod, iPad, MP3 Players, Tablet, GPS, DV Recorders, Mobile Phone, Android Phone, Cell Phone, Blackberry, HTC, Samsu
DISCLOSURE:
I've linked to commonly available online suppliers including B&H but this is not necessarily an endorsement nor a promise of best available prices and service YMMV.
I've not tried the combo myself (yet) so it is unproven. I will try and update my post later, interested to hear if anyone else tries this they should let us know how that worked for them.
I've freely provided here what I do know and shared at no cost. If you're not interested in DIY I would not mind selling you a kit put together myself
Based upon the DC Coupler supplier warranties, this solution should work equally well for Pentax K-30, K-50, Kr and K2 DSLR camera bodies.
05-19-2014, 12:25 PM   #78
QuoteOriginally posted by Pewter Quote
3
useless for Your application thing. do not try it.
it is a 5V out battery (for 1 cell Li-Ion device charging, cellphones ets.)
attached AC adapter will kill Your camera for sure
battery and charger may help - http://www.ebay.com/itm/4400mAh-8-4V-Rechargeable-Li-ion-Battery-Pack-for-Bi...item25826ffb93
even bigger, but You need loooooong time to charge it.
BUT - DOES NOT USE charger as power supply - it quiet sure will kill camera. it is not power supply - it is a charger.
05-20-2014, 10:13 AM   #79
Pewter's Avatar
QuoteOriginally posted by pentajazzz Quote
I applaud your caution, take your advice seriously and am certain you are the most skillful modder here. Nonetheless the EZOPower Black 3 -Port kit device is NOT a 5V output else it could not power various Canon and Nikon models shooting video for hours as seen in real-life settings here -- www.youtube.com => Increase Your DSLR Camera Battery Life To 9 Hours! // Chris Winter but you decide.
PentaJazz you separately advised using 8.4V (as opposed to 9V, because that would be closest to replicating an actual battery pack). Then do you think I could adapt this Lanparte product to the K-30 for purposes of 6hr extended battery life?
-- http://www.lanparte.com/d/file/Products/two/2012-09-03/a2d2e3f906f2af002f1a3c330a3584e5.pdf
-- http://hz01.i.aliimg.com/img/pb/431/184/516/516184431_819.jpg
05-20-2014, 10:35 AM   #80
oh, nice to know...
Yes, You can to use it.
it is 2cell Li-Ion pack (7.4 V nominal it is mean fully charged 8.4V, it is Ok)
just new battery adapter needed. try to by some cheap D-Li90 (6-7 USD), carefully disassemble it and reconnect instead of original adapter.
01-11-2020, 02:04 AM   #81
I'm not sure I understood where to connect the cable
Hi,
1 - standard 3.5mm jack was diassembled, shorted by leight from the cable side, and after what was connected the cable, the housing You are can see - it is a CA thick glue, above the soldered cable. black color - permanent marker.
I was thinking about cable from inside of camera, but battery compartment is restricting access to 2.5mm male jack from inside of the body.
or, of coarse, if you are want to almost totally disassemble the body - sure You can to make this connection.
2 - cable to 2.5 mm plug is very thin, it is a twisted wires from quality earphones. black insulation is ended 1 mm under the rubber body plug (it is not completely closed, do You see?), and after that wires goes naked (they are have thin insulation), 2.5 mm plug is also shorted, and soldering point covered by CA glue drop (CA - instant glue, but "thick" type)
from the body rubber pug removed only approx 2/3 of cross ribs are catted out. if I will disconnect 2.5mm jack - the rubber plug is fully working and seal the 2.5mm port as it needed.
3 - You can use k-30 battery, and K-5 battery as well,
remaining power WILL DO be correctly displayed, it is a same type (Lithium-Ion) battery and they have same discharge curve. difference is only at capacity, so then You have "half" - it will be HALF from 1050mAh or half from 1850mAh - not important. it is HALF. (or quarter, or 3/4.....)
but - if it is a D-Li109 half - it is 200 pictures, or if it D-Li90 half - it is a 400 pictures.
pay attention, the D-Li90batt, purchased with grip or separately possibly will be lower capacity, then noted. if it noted as 2000mAh, it may be true 1200 or 1600... never-mind, it is normal for china-market batt.
just by more.
I have four D-Li109 non OEM batt and they are noted as 1400mAh, but really 2 of them are true 1050mAh, one 800mAh and last one only 600mAh.
but it works, and still 1/4 price from ONE OEM D-Li109...
chargers for 90 and 109 batteries are different...
Hallo and thank you.I'm not sure I understood where to connect the cable inside the grip...could you explain better? Do I have to connect it to the shutter release button? At the end, what will work on the grip? Thank you!
adapter, batteries, battery, battery grip pentax, camera, dont, flu, grip, hours, k-30, k-50, nikon, pentax, pentax k30, pentax k50, piece, power, size, smartphone, weight
K30 Grip vs K5 Grip CMG Pentax K-30 & K-50 9 11-26-2012 01:45 AM
For Sale - Sold: Pentax D-BG4 Battery Grip + D-L190 Battery noahpurdy Sold Items 2 08-19-2012 10:57 PM
For Sale - Sold: Pentax K20D with Battery Grip + Extra Pentax Battery Braddokovik Sold Items 3 02-03-2012 04:28 AM
For Sale - Sold: Pentax Battery Grip D-BG2/D-L150 Battery doch4m Sold Items 4 01-04-2012 05:57 AM
For Sale - Sold: Pentax D-BG2 Battery Grip in Like New condition + Generic Battery jjdgti Sold Items 2 07-15-2010 06:06 PM
All times are GMT -7. The time now is 06:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
