03-07-2013, 09:43 AM   #1
adwb's Avatar
Histogram display query
I got offered a v good price for my Kr and since could get a ex demo k30 for the same money I grabbed the opertunity.
apart from the odd grip which I guess I will get used to, I have found one oddity in the menu which I can't get round.
On my k5 / kr / k10 if I press the info button while in review you cycle through the various display options.
On this k30 if I press the info button I get a screen with a choice of which one I want, surely there must be a way to get this to behave like a normal pentax info display cycle?
03-07-2013, 09:52 AM   #2
Try pressing the OK button. It may cycle through the different display options, but I'm not 100% sure.
03-07-2013, 11:53 AM   #3
adwb's Avatar
Adam nice idea but it just turns off whichever one you selected
03-07-2013, 12:11 PM   #4
It can't do it. I've been looking for 3 months!
03-07-2013, 02:41 PM   #5
All the display options are accessed throught the menu button, go to the wrench icon and display options are under #1. If that is not what you are after please clarify.
03-07-2013, 03:01 PM   #6
adwb's Avatar
QuoteOriginally posted by Steven Chain Quote
What earth are you on about? My query is perfectly clear, Adam under stood it ,and the menu options you suggest do not relate to my query.
03-08-2013, 07:52 PM   #7
wildboar's Avatar
The functioning of the info button on the K30 is my biggest gripe about the camera. My K-01 is the same way. The 'old' way (K5 and prior models) seemed much better, and I'm not sure why Pentax would think the current method is better.
03-08-2013, 08:52 PM   #8
QuoteOriginally posted by wildboar Quote
The "new" way is better if you want the same screen to come up each time you hit the review button. If you select the histogram display (via the Info button) then it becomes the persistent option until changed. This way you only need to hit the review button to get the histogram for all subsequent shots. The Info button doesn't need to be pushed unless you then want to switch to one of the other display options. Whatever screen you exit the review from becomes the new default.
Some may like this better, some may like it worse... but there is a logic to it.
03-09-2013, 02:23 AM   #9
QuoteOriginally posted by IchabodCrane Quote
They could combine the 2, then it would be perfect. i.e. leave it as it is but add being able to cycle through the different screens with each INFO press and remember that type of screen throughout power cycles.
03-09-2013, 04:15 AM   #10
adwb's Avatar
it now turns out that apart from the info button change debacle,
the pop up flash has been completely re-designed so the Aotec wireless pttl sender does not fit.
and the only software to allow tethered shooting also cannot be made to work by the programmer he says there is some major firmware change but he has a update for the newest k5 models.
It's a pity that when reviews are undertaken that this sort of thing is not discovered especially here on the Pentax forum reviews .
Quite frankly I would have kept my K-r if I had reaslised the pop up and tethered issues existed.
03-09-2013, 10:01 AM   #11
wildboar's Avatar
Ichabod, on the K5 the histogram setting was persistent once it was set. That hasn't changed. The method for changing the view to something different is what has changed, and it is now more complicated (two buttons as opposed to a single button).
button, cycle, display, info, k-30, k-50, k30, kr, pentax k30, pentax k50, press
Histogram help Colbyt Digital Processing, Software, and Printing 5 01-12-2013 07:16 AM
Histogram in display of K5 everydaylife Pentax K-5 3 08-16-2012 02:49 AM
Histogram Patajac Digital Processing, Software, and Printing 6 06-05-2012 09:56 PM
Histogram Mapleleaf-Mick Pentax K-5 5 08-25-2011 06:14 AM
K10D histogram display jjfdvm72 Pentax DSLR Discussion 3 12-15-2007 08:44 PM
All times are GMT -7. The time now is 02:59 PM. | See also: NikonForums.com, part of our network of photo forums!
