04-23-2013, 11:23 AM   #31
i've just updated from 1.00 to 1.04 what have I missed.I've not had any screen bugs the only thing I've had is that it has a problem with 32gb cards
04-24-2013, 10:31 AM   #32
I'm running 1.00, I got my camera a couple weeks ago, I guess the store I bought it from doesn't get much turnover on their Pentax stock! I have experienced an intermittent memory card error also (32gb Lexar platinum II). I'm wondering if it is worth updating the firmware, with hopes that it will remedy this problem, or if 1.04 will introduce more problems in other areas...
04-24-2013, 11:29 AM   #33
Pentax cameras always seem to come with the original firmware.
04-24-2013, 01:45 PM   #34
EarlVonTapia's Avatar
QuoteOriginally posted by forc Quote
Lexar cards are crap on the K30.
I was using a SanDisk 8gb card for months and it worked perfectly fine. No errors ever. I've recently upgraded to a 16gb Eye-Fi card. No errors so far after maybe 600 or so shots.
I briefly used a Lexar 32gb card at the end of last year because I picked one up on sale. I would say I experienced problems about 50% of the time. It now sits in a box on my shelf because the store wouldn't accept a return on an opened memory card. I won't even trust it as a backup card (my 8gb SanDisk gets the nod).
It's the card.
EDIT: Also, I'm still on the original 1.00 firmware until Pentax releases some drastic performance update or a killer feature upgrade.
04-24-2013, 08:48 PM   #35
QuoteOriginally posted by EarlVonTapia Quote
It's the card.
Di you format the card in-camera? If you didn't it is a good idea to do so. As stated, not all bug fixes are documented as some are minor fixes. It is good to upgrade to the latest firmware to fix bugs that were stated and for those that were not stated.
All my cameras were updated to the latest firmwares and I have no issues with the cameras.
04-24-2013, 09:59 PM   #36
QuoteOriginally posted by felixkh Quote
I used to format the card in camera. Now I just delete all the images. I've read reports in favor and against each method. It doesn't matter to me.
Upgrading is a hassle. No thanks. The camera works fine as is.
04-25-2013, 05:04 AM   #37
You should always format a new card in camera and fairly frequently thereafter. Deleting the images does not delete everything and there is garbage left on the disk and if you don't format in camera perhaps not every time but regularly. the probability of errors increases significantly.
Is it possible that using 32 Gb cards has an occasional glitch that was one of the unstated fixes in one of the updates?? Updating is so simple and straight forward why wouldn't you want to be running what the manufacturer says is the latest and greatest. Most firmware upgrades are not major enhancements or new features but rather minor glitch fixes that only happen occasionally but why take the chance that a randomn glitch could ruin a critical shot?
04-25-2013, 05:44 AM   #38
You've had major problems with a Lexar card and yet "the camera works fine as is".
04-25-2013, 09:19 AM   #39
QuoteOriginally posted by IchabodCrane Quote
The 8GB card that came with my camera got me clear past 10,000 clicks with no issues.
The new 16gb EYE-Fi card I have, a much more complicated piece of technology, performs flawlessly in all its functions (approaching 1000 shots).
The 32GB Lexar decided not to save 1/2 of the shots taken with it right from the get go. When researching the problem, I came across other reports of buggy issues with that particular Lexar card model. It's probably the reason why it was on sale in the first place.
I'm going to pin the blame on the Lexar card. It is the simplest explanation.
If I need to use a 32GB card for whatever reason, I'll just buy a card that's proven to work instead of one that's on sale.
QuoteOriginally posted by bcorson Quote
I remember researching the whole "delete all images VS reformat card" when I first started, and I couldn't find a definitive answer at the time, so I just picked one and stuck with it. I have yet to encounter any problems. Maybe I'm just charmed.
As for not upgrading, I am now invoking the "if it ain't broke don't fix it" rule. I'll deal with problems when they actually happen, not when they "possibly potentially might randomly" happen.
04-25-2013, 09:36 AM   #40
I've had memory card errors with both formatted and un-formatted.There was a similar discussion here:
https://www.pentaxforums.com/forums/pentax-k-30/204862-card-error-file-cannot-stored.html
I think it is the card, I used a SanDisk 4gb card with no problems. Apparently it is an issue with the physical dimensions of the card, even though they are supposed to be standardized.
Also for the update, is there a detailed list of corrected issues? The website is kind of general,
ie. Corrected Unstable performance may rarely occur in firmware version 1.03... What kind of unstable performance?
I think I'll try the firmware update when I get home, but there is no specific instance where the error occurs, so I'm not sure how I'll test it...
04-25-2013, 10:04 AM   #41
QuoteOriginally posted by Anthony Offen-james Quote
If firmware bugs were obvious, Pentax would probably not be making cameras
04-25-2013, 12:26 PM   #42
I was going to explain why I format new cards in camera before using and why sometimes I reformat in camera instead of just erase but a quick search turned up the following link When to erase and format a memory card? which saves me typing and likely explains things better then I would.
BTW, isn't a bug by definition something that happens randomly or as you say "possibly potentially might randomly" happen while if something happens all the time it is an out right error or fault?!
04-25-2013, 05:40 PM   #43
Thanks for the link. Essentially, only deleting the images is fine, but I should be reformatting in camera once in a while. Makes sense. Every 5,000 clicks or so should be good. I'll have to see how that plays out with the Eye-Fi (not sure if it will completely wipe the settings, which would be pain), but for a regular card I can dig that.
Not sure what a bug is. I'll let the wordsmiths figure it out while I'm out taking lots of photos with my firmware version 1.00 K30.
04-25-2013, 05:44 PM   #44
How many 32 GB cards have you used without any issues in the camera?
04-25-2013, 06:21 PM   #45
Um, none? Because I've only tried the 32GB Lexar, and when it didn't work I tossed it into the memory hole on my shelf.
And I haven't needed another 32GB card, so I haven't tried others.
Heck, this 16GB Eye-Fi card is overkill for me, I only got it because I wanted the Eye-Fi capabilities, and it was only $20 more than the 8GB Eye-Fi card.
IF I ever feel the need to use 32GB Lexar cards for whatever reason, and IF there's a firmware update that's proven to make that card work, then I might think about perhaps possibly upgrading the firmwares. Maybe. Or I may just buy a different 32GB from a better card maker, whichever is easiest at the time this issue might possibly arise. It's probably going to be the latter.
Anyways, I think I should stop because I'm becoming a prickly fanboy.
Needless to say, for any new K30 owners following along on this thread wondering if they should upgrade the firmware or not, know that there are people like me still on the original version 1.0 firmware who are happily shooting away with perfectly functioning K30's who don't miss the .0005 second boost in live view autofocus speed that firmware 1.143 promised to deliver. You will not be alone.
Seacrest out.
k-30, k-50, pentax, pentax k30, pentax k50, v1.04
K-01 Firmware update - V1.02 Docrwm Pentax K-01 42 05-04-2013 06:04 AM
Firmware update v1.01 for Q10 Mistral75 Pentax Q 3 02-20-2013 03:55 AM
Apple Digital Camera RAW Compatibility Update 4.04 i83N Pentax News and Rumors 23 02-15-2013 05:45 AM
k20d v1.04 firmware barn154 Pentax DSLR Discussion 4 08-21-2010 02:32 AM
K20D Firmware v1.04 nanhi Pentax DSLR Discussion 5 05-13-2010 08:17 AM
All times are GMT -7. The time now is 03:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
