Originally posted by Zafar Iqbal The AF accuracy fluctuates more using v1.04 than v1.01. Even when the focus is close to where I need it to be, v1.01 beats it by being closer.
Then there's a thing with the AF being *way* off. It happens. No biggie, just re-focus and nail the shot on the second exposure. That's how it typically was, but with v1.04 (and v1.03) it's way off more frequently. Re-focusing won't necessarily help for the next several shots.
So, generally speaking, pics are less in focus (not all but many) - this is most noticeable when using shorter focals - and focus out of the blue gets thrown off at a greate rate.
I've tried different lenses though not used same amount of time with them all. The behavior seems to be present with all of them.
That is weird and certainly not good. I would find that extremely annoying. I should also have asked if the whole image is out of focus or if what you thought you focused on is out of focus but somewhere in the image it is properly focused. Have you tried using spot focus as opposed to the other choices to see if it is better? Using spot focus lets you be absolutely certain where the point is that you have focused on. Does this happen when you use all the focusing methods? What do you mean focus out of the blue?
Got to be more then just firmware going on or more folks would have the issue. Might be worth trying different focus modes and combinations to see if some settings work better then others. For example does it happen in Live view as well?
Does spot work any better for example. I will try some combos later today or tomorrow and see what happens. ANy chance yo could send me a large file showing an example?
Bob
