07-21-2013, 10:01 PM   #76
Battery
Have to agree there - Mine goes from Full to Empty instantly
It was fine when I got out of the car and took this photo This is as far as the car goes | Flickr - Photo Sharing!
Having climbed through soft sand to the tombs - Several rest stops and lots of water were required - I went to take the first photo and the battery was flat!
Fortunately my guide ran back down to the car and came back with two types of incorrect batteries, but brought the 6 year old, twice round the block *ist as well!
07-22-2013, 07:26 AM   #77
JimJohnson's Avatar
QuoteOriginally posted by wed7 Quote
One thing I dislike on my K-30 after the FW update is that the battery meter is not that accurate, I use black Eneloops instead of the lithium btw.
Do you go into the menu and change the AA battery type from 'Auto' to specifically indicate the type in use? 'NiMH' when using eneloops. It helps, but is far from perfect.
07-22-2013, 08:00 AM   #78
QuoteOriginally posted by JimJohnson Quote
Missed that in the manual!
Thks
07-22-2013, 05:36 PM   #79
Thank you Jim
07-22-2013, 07:34 PM   #80
cynthiaspiers's Avatar
problems focusing
Hi, have you experienced any problems when you focus after installing the latest firmware update? I was just comparing my first pictures with the new ones and the first ones were very crisp... I am using the same lens and speed...
07-22-2013, 09:15 PM   #81
QuoteOriginally posted by cynthiaspiers Quote
I did. I've seen an improvement after downgrading to 1.01 (I would do 1.0 but that's not avail anywhere I've looked). As weird as it may sound the quality of the JPEGs is a bit better too (at least what I've noticed). I have not ran lab tests, this is just my opinion.
10-15-2013, 12:31 PM   #82
So what is the verdict on 1.04. Should i upgrade(1.0) or not?
10-16-2013, 06:44 PM   #83
QuoteOriginally posted by saajlas Quote
The latest one is V.1.05
You can check upgrade information from Ricoh website.
10-16-2013, 07:16 PM   #84
Tsuken's Avatar
QuoteOriginally posted by patrick9 Quote
I was beginning to think I was the only one left using 1.00 firmware
Only just got my k-30, and it's running 1.0
10-16-2013, 07:23 PM   #85
Tsuken's Avatar
And reading this thread, and looking at what the firmware updates address (I don't use Live View, for a start), I think I might just as well stay with 1.0 which is working just fine and dandy.
10-17-2013, 07:08 AM   #86
firmware
Mine is also on ver. 1.0, and i`m just wondering if they addressed known issues or just introduced new ones. I`m new to Pentax system so i don`t know if it`s wise to update firmware or how it usually works with Pentax updates.
10-17-2013, 11:45 AM   #87
Personally,, i am reminded of that old saying "If it ain't broke don't fix it".
Ricoh has acknowledged on their website that firmware 1.03 caused instability. I would say, if you don't have a need that is directly related to the issues the new firmware addresses,, then don't mess with it.
I'm at firmware 1.01 and have not noticed a need to upgrade it yet.
10-17-2013, 01:36 PM   #88
Thanks OldNoob.
12-28-2013, 07:42 AM   #89
Hi,
I have Version 1.0 on the old firmware, have followed the steps on the Update page for V1.05 and cannot even get the camera to upgrade at all. I have formatted the SD card using the camera and have the DCIM folder. Downloaded the update file no unzipping required according the instructions. The firmware info/options just stays at the version screen and does not give me the opportunity to upgrade. Any help would be greatly appreciated.
Cheers
12-28-2013, 07:59 AM   #90
No worries, have solved it - I did need to unzip the file Doh!!
k-30, k-50, pentax, pentax k30, pentax k50, v1.04
K-01 Firmware update - V1.02 Docrwm Pentax K-01 42 05-04-2013 06:04 AM
Firmware update v1.01 for Q10 Mistral75 Pentax Q 3 02-20-2013 03:55 AM
Apple Digital Camera RAW Compatibility Update 4.04 i83N Pentax News and Rumors 23 02-15-2013 05:45 AM
k20d v1.04 firmware barn154 Pentax DSLR Discussion 4 08-21-2010 02:32 AM
K20D Firmware v1.04 nanhi Pentax DSLR Discussion 5 05-13-2010 08:17 AM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
