04-08-2013, 01:38 PM   #1
K-30 movie shutter speeds
Hello everybody,
I have bought my K-30 last week and have enjoyed playing with it. This is my first camera capable of recording movies and I will probably be taking it to some local air displays in the summer. I am aware that filming propeller aircraft can be tricky because if the shutter speed is too high it will appear as if they are turning very slowly. Now my qustion is this. Is it possible to regulate the shutter speed whilst filming or is everything done automatically?
04-08-2013, 01:57 PM   #2
QuoteOriginally posted by leader400 Quote
Hello everybody,
Yes, the K-30 offers manual controls. The only thing you can't change is the ISO AFAIK.
04-08-2013, 02:01 PM   #3
Thanks Adam. Do know how I can can change the shutter speed? I can see how to change the frames per second, but not the shutter speed at any given fps.
John
04-08-2013, 02:33 PM   #4
VisualDarkness's Avatar
If it's like the K-5 you go into the video part of the menu and put something like "exposure control" (can't remember) to manual instead of auto.
04-08-2013, 02:54 PM   #5
John
In the movie menu, you can choose between M, Av, and P. You'll want to select M mode.
04-09-2013, 12:25 AM   #6
adwb's Avatar
I was sent this by Na Horuk which might help you:
"Here are some more details:
FPS: Choose the ones between 24 and 30. Use 60fps only if you want to slow down the footage later, for a slow motion effect, for example. If you choose 60fps for regular video, the files will be huge and the video will be a bit "odd" looking. 30fps is for NTSC recording, and 25fps for PAL (this may be important, depending on your region, but since you will probably only view files on a computer, not so much). 24fps is often referred to as "cinema look."
Resolution: There is this idea that "bigger is better" but it really isn't. You can have high resolution if you want to watch it on an HD TV, or if you want to post process the video a lot. But for computer viewing or emailing, social media sites, a smaller resolution will be just fine and take much less space.
Shutter speed: Generally you want to set the shutter speed to approximately 1/(2*frame rate). For example, 24fps should use 1/50 shutter. A faster shutter will make things look twitchy. A slower shutter speed will cause motion blur.
ISO: Keep it low, but bring it up higher in dark places.
Aperture: Same as when taking stills, a smaller f number means more light is captured (which is great for dark places) but also a shallower DoF.
Quality: lower quality means more detail is lost, but the file size will also be smaller. You probably want the quality set to high.
There is also a problem with CMOS DSLR camera video called the "rolling shutter" or "jello effect" - you can't do much about that, other than taking care what subjects you take video of and how you position yourself. You can try lowering the shutter speed and masking the jello effect in motion blur, but this might not be suitable for all situations.
One more thing is that even a compressed video from a camera will still be quite big. Most of the time you will want to run your video through some video editing software, which will bring down the size with minimal loss of quality. If you do this, you can also shoot in highest resolution and quality, and then just trim it down in the editor according to your needs.
Hope this cleared up some terms. The best is to do some tests and decide what is best for you and what you find to be still acceptable.
Oh, and for computer viewing I use the second smallest resolution with highest quality and at 25fps. The rest is usually automatic. If I want to take video of something "more important" or as a project, I just switch the resolution to highest, and fps according to the scene."
k-30, k-50, pentax k30, pentax k50, shutter
k-7 vs k-30 shutter noise Conqueror Pentax K-30 & K-50 9 04-06-2013 09:10 PM
Guidelines re shutter speeds? beaumont Photographic Technique 6 12-05-2011 08:27 PM
K10d is blurry at slow shutter speeds speterlewis Troubleshooting and Beginner Help 7 09-11-2011 11:17 AM
ME Super not firing correct shutter speeds mikengstrom Pentax Film SLR Discussion 5 07-25-2011 01:40 PM
K-7 and shutter speeds in P matthis Pentax DSLR Discussion 10 10-08-2009 02:22 AM
All times are GMT -7. The time now is 12:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
