04-13-2013, 09:16 AM   #1
Aperture Settings
Please excuse my ignorance in this question. We have two K30s at home and with two DA 3.5-5.6 18-55mm Lenses. In Manual mode we are sometimes locked out for a going to the MINIMUM aperture setting. Stuck at F4.5 sometimes 5.6, either way I can never set either camera with either lens to F3.5. Been searching the web, searching this forum, unsuccessfully looking for answer. Maybe I am not using the correct search terms. Either way I am looking for answer to this query. Many of my other lenses work perfectly for never been stuck for a min aperture setting.
Any information would be appreciated.
04-13-2013, 09:23 AM   #2
Probably a daft question:- are you checking at 18mm?
04-13-2013, 09:25 AM - 1 Like   #3
The minimum aperture changes based on the focal length - so the more telephoto you've set your lens, the higher the minimum aperture will be. This means that at 18mm zoom, the minimum aperture will be 3.5; at 55 it will be 5.6, and it changes somewhere in the middle. You'll just have to either shoot at a shorter focal length or get a better lens.
Hope that helps!
04-13-2013, 09:38 AM   #4
Thanks Jellinga, that was awesome information. Never looked at lenses properly for understanding that. That was awesome.
answer, aperture, k-30, k-50, lenses, pentax k30, pentax k50, setting
Metering/Needle/Aperture Settings jtkratzer Pentax Film SLR Discussion 7 11-18-2012 02:02 PM
Outdoor Settings jbuck92 Troubleshooting and Beginner Help 18 12-30-2011 12:48 PM
Aperture settings via lens on K-x Gary G Pentax SLR Lens Discussion 5 11-16-2010 06:10 PM
Aperture and Shutter Settings buckethead Pentax DSLR Discussion 24 07-14-2008 04:51 AM
aperture settings for detailed foreground and background lordson Photographic Technique 4 11-10-2007 08:16 AM
All times are GMT -7. The time now is 10:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
