Originally posted by simbon4o All K30 and K-01 cameras not only mine have this problem, when automatic lens(A, F, FA, DA) is attached they close the aperture in LV during focusing. If the lens is set manually to exact aperture by aperture ring - it works like K/M lens in LV and the aperture stays opened.
That's too harsh, you can only remove the aperture lever who hits the mirror of canon FF cameras and works for the auto aperture on pentax cameras - much more easy and reversible.
Its also a curse of keeping K-mount compatibility, the lever is there to interface with the camera aperture mechanism like it or not.
We can say its a stupid implementation, but I think Pentax is just covering themselves from liability.
I think the stopping down also prevents the screen from being whited out.
We can also say that we will be gracious and not pursue free camera repair in the event that the sensor is damaged, but there are tons of ppl out there who are not so gracious.
Ppl do that all the time, their Iphones/GalaxyS gets dunked in the toilet bowl or pool or whatever, they dry it up and send it in for servicing claiming warranty for a defective product.
Personally, I just make do with the green button metering. (but I must say that its more clunky to use it that way)
As for chopping the aperture lever for a 5D, it depends on lens.
Some levers can be easily removed by unscrewing.
For others, the lever is attached to the aperture ring mechanism.
These are the ones that need to be snipped off.
One more elegant way is to find a junk/fungus/'for parts' lens that has the same mechanism, snip off the lever from that and use it on the good lens.
