04-16-2013, 08:59 PM   #1
brand-new k-30: does not turn on!
hello all,
i am the new owner of not one but two brand new k-30s from costco. the first one arrived, i followed the instructions to put it together, charge the battery, insert the card etc etc to a t. ... and the camera didn't turn on. called pentax customer support and was advised to return the camera and get a new one... which arrived today and almost the same thing happened: this time, i charged the battery and inserted it but did not bother to attach a lens or insert a card. i just wanted to see if it turned on. which it did, so i turned it off and went back to work. came home, attached a lens, inserted a card and: nothing. thought maybe the card is corrupt so inserted a different one: nothing. thought maybe the battery discharged: charged it again: nothing. took the lens off and the card out and for about ten seconds, the camera turned on long enough to tell me that there's no card in it. i put the card in: nothing.
has anyone ever heard of this? i have two cameras sitting here that are brand new and don't work! advice please!
tomorrow morning i'm calling pentax tech support once more and then its back to costco to return both of them unless someone can enlighten me.
thanks in advance
04-16-2013, 09:26 PM   #2
VisualDarkness's Avatar
That sounds almost impossible, two non-functioning in a row. What are you looking at? Have you tried to check that the LCD isn't turned off (Info button on the K-5 at least)? Do you see data when looking through the viewfinder?
04-16-2013, 11:09 PM   #3
Did you try to look into the view finder to make sure the camera was not on ? With the lens attached, look in the view finder, lightly push on shutter button as you try to have it focus, look at the bottom in the view finder if you see some informations display then the camera is on. K30 with old firmware will turn off rear monitor in real short time.
04-17-2013, 12:41 AM   #4
altopiet's Avatar
How long did you charge the battery? Are you sure you inserted the battery into the charger as per instructions in the manual? If I remember correctly, my first charge took a few hours before it was fully charged. Are you sure that you inserted the battery correctly into the camera? Somehow I just get a feeling this is a battery related problem....
04-17-2013, 10:19 AM   #5
QuoteOriginally posted by altopiet Quote
I tend to agree. The only other thing I can think of is the first card has an internal short and it instantly blows the K-30 motherboard.
04-17-2013, 10:22 AM   #6
JinDesu's Avatar
On the back of the k-30, lower right side, there is a translucent circle. That circle lights up when inserting a SD card (or at least, that's what happens on my k-x).
When inserting a SD card with a charged battery, does that thing light up? It doesn't need the camera to be on to light up.
04-17-2013, 06:19 PM   #7
K30 wont turn on
You have to have a memory card in the slot or it won't turn on . By now you probably already know that.
04-17-2013, 07:10 PM   #8
FruitLooPs's Avatar
QuoteOriginally posted by SteveB Quote
I agree, look for a common thread. I'd go with either user error, a singular duff memory card as you say or two bad ones (not counterfeits? they are around).
I've not seen or heard any reports of DOA K-30's and for OP to have gotten two, seems to be an extremely slim likelyhood (unless a batch are stuffed and costco happen to have 'em).
Try a different brand memory card if you haven't.
04-17-2013, 08:27 PM   #9
apfhex's Avatar
QuoteOriginally posted by marquis1955 Quote
You have to have a memory card in the slot or it won't turn on.
Mine turns on just fine without a SD card. But I still also thought that could be the culprit if its a bum card or the K-30 just doesn't like it for some reason.
04-19-2013, 02:24 PM   #10
Check if the memory card door is fully closed. If it is not, K30 wont turn on.
04-20-2013, 05:55 AM   #11
monochrome's Avatar
OP post 04/16. Most recent reply 04/19 and no responses to suggestions from OP.
battery, brand, camera, card, costco, k-30, k-50, lens, pentax, pentax k30, pentax k50, return, support
Macro Brand New K-30 searat3030 Post Your Photos! 2 02-20-2013 09:46 AM
Pentax K-30 + Sigma 18-125, AF does not work plehto Troubleshooting and Beginner Help 4 01-27-2013 10:35 AM
K-5 will not turn on - Pentax Support advice carrrlangas Troubleshooting and Beginner Help 2 01-10-2013 11:02 AM
For Sale - Sold: Pentax K-30, black, BRAND NEW Quazimoto Sold Items 7 08-29-2012 04:55 AM
Shutter count tool does not work with K-30 Edgar_in_Indy Pentax K-30 & K-50 7 07-28-2012 02:54 AM
All times are GMT -7. The time now is 01:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
