04-26-2013, 09:11 AM   #1
MF Assist, x2, x4 for K-30
...my Q has a menu command for MF Assist, x2, x4 ... does the K-30 have similar menu functionality, and if so, what is it called ???
04-26-2013, 09:23 AM   #2
altopiet's Avatar
Press "ok" and scroll right with back scroll wheel. (read e-dial)
04-26-2013, 10:54 AM   #3
...thanx for the reply, I believe this provides a 2x, 4x, xx increase in the size of the auto focus area on a K-30...the MF Assist on the Q provides a 2x,4x increase of size of the viewed image on the live view screen...thanx
04-26-2013, 01:10 PM   #4
...I stand corrected, Altopiet was correct, IF you set the K-30 to MF ( on the focus selection switch) and Live View and press the OK button, then you can select 2x, 4x, or 6x image magnification on the Live View Panel...perfect-o !!!
if you leave the K-30 focus selection switch in the AF.S position and press the OK button then you can select a XX increase in the available AF area, or something like that....
...if you have a K-01 you can leave the focus selection switch in either AF or MF and by pressing the OK button you will be able to increase the viewable image by 2x, 4x or 6x by using the command/control wheel ...goodie !
...and I did read a previous post that the K-30 in ViewFinder (SLR) operation will display a Green Focus Confirm Octagon when the lens is in focus, and the shutter release is pressed half way...and that is correct, and, the K-30 viewfinder is so bright and clear you can visually focus a MF lens and confirm correct focus by the display of the Green Octagon with a half way press of the shutter button
to each their own
WHEW !
k-30, k-50, menu, mf, pentax k30, pentax k50, x2, x4
Manual focus assist & MF lenses GibbyTheMole Pentax Q 9 02-08-2013 05:12 PM
MF assist point photoman1 Pentax DSLR Discussion 10 12-26-2012 07:36 AM
Pentax e-books for the K-30 and K-5 $9.89 for this weekend ebooks4pentax Pentax Price Watch 3 11-26-2012 08:48 AM
For those of you with both the K-5 and K-01 or K-30... cali92rs Pentax DSLR Discussion 3 11-12-2012 07:10 PM
K-30 MF focus assist off! DrDespair Pentax K-30 & K-50 8 08-04-2012 02:56 AM
All times are GMT -7. The time now is 09:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
