05-03-2013, 03:18 PM - 1 Like   #1
Powerstroke 7.3's Avatar
Finally have a camera on the way!!!!
Finally - I ordered a camera bag a while ago without anything to put in itother than my wife's point and shoot... I just ordered my K30 with the 18-135 .This will be my first camera for me ever...no wait, I had a point and shoot35mm back in the early nineties. I have learned a lot here but I know I havenot even scratched the surface and look forward to advice from here. I plan onoutdoor nature shots and I am looking at the 55-300 when I purchase a zoomlens.
05-03-2013, 03:21 PM   #2
Senior Moderator
Parallax's Avatar
Congratulations. Sounds like a nice setup.
(Cummins 6.7 )
05-03-2013, 03:25 PM   #3
Ex Finn.'s Avatar
QuoteOriginally posted by Parallax Quote
(Cummins 6.7 )
Powerstroke...that would be a FORD. Yea.
05-03-2013, 03:27 PM   #4
Ex Finn.'s Avatar
QuoteOriginally posted by Powerstroke 7.3 Quote
Lot of bang for the buck with that lens.
edit: the only drawback is that it is not WR like the 18-135. But it has very good reach without the dollar penalty.
05-03-2013, 03:40 PM   #5
hcc
hcc's Avatar
...I just ordered my K30 with the 18-135 .T..I plan on outdoor nature shots and I am looking at the 55-300 when I purchase a zoomlens.
Congrat for the purchase. You will be happy.
The 55-300mm would overlap broadly with the 18-135mm. By cropping your photographs, you can artificially zoom beyond 135mm with your existing 18-135mm lens. I would suggest that you use the 18-135mm first to ascertain what are your needs.
Food for thoughts..
05-03-2013, 04:01 PM   #6
vagrant10's Avatar
That's a great weather sealed set up to start with. Should be able to get you some great photographs if you're in the right spot at the right time. It's a lot to learn, but once you get a shot you're proud of, print it large and you'll be hooked on photography for a long time!
Depending on whether you like to do wide landscapes or if you're doing critter shots, that will determine if you need a wider lens (like the 12-24, or 10-20 etc) or if you need something with longer reach like the 55-300. More than likely though, you'll want both and then some more
Have fun with your new tool!
05-03-2013, 05:51 PM   #7
patrick9's Avatar
Enjoy your K-30 it's a fun, very capable camera
05-04-2013, 05:13 AM   #8
Thanks for encouragement. Looking forward to getting the camera and takeing pictures of my Powerstoke extended cab, 6spd manual superduty.
05-04-2013, 05:29 AM   #9
Senior Moderator
Parallax's Avatar
Great, then I'll post some of my Dodge Cummins crew cab long bed so you can see what real truck looks like.
Seriously, enjoy the forum and and the camera.
05-09-2013, 06:16 PM - 1 Like   #10
As promised the F250 - one of my first pictures taken with my K30 I got today.
PENTAX K-30  Photo
camera, k-30, k-50, pentax k30, pentax k50
Eureka! - Finally a good cheap way to dry clean the sensor GibbyTheMole Pentax DSLR Discussion 12 10-03-2012 07:03 AM
I have no camera and don't know which way to go pjtn Pentax DSLR Discussion 6 06-27-2011 07:00 AM
JPEG shooters: here's a way to lift the shadows - in camera asp1880 Pentax DSLR Discussion 19 05-12-2011 06:00 AM
Camera on the way, lenses on the way, what am I missing? Balog Troubleshooting and Beginner Help 30 07-08-2010 01:38 PM
Finally, a camera that the Lensbaby Composer doesn't look bad on! inferno10 Pentax DSLR Discussion 3 11-26-2009 01:11 PM
All times are GMT -7. The time now is 10:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
