05-13-2013, 06:36 PM   #1
ccrookston's Avatar
K-30 White Balance... can't adjust
I'm pretty sure that right after I post this I will find the solution and then feel silly. But that being said, I'm still playing around with my new K-30, and for whatever reason, I can't figure out how to adjust the white balance. When I try to push down on the bottom button of the 4-way, I'm told, "This function is not available in the current mode."
WHAT mode? The manual says, I should try this in stand-by mode. What the heck is stand-by mode, and how do I get there? I can't find anything in the manual that says "standby mode". Also, when I have the camera in manual select-focus mode, NONE of the 4-way buttons are available, except to select the focus.
I knew everything on my old K10d so well.... I feel like I'm learning to make love to a new partner, and it's frustrating. Any tips?
05-13-2013, 06:40 PM   #2
QuoteOriginally posted by ccrookston Quote
Your camera is probably in green mode. Put it in P mode and you'll be golden.
05-13-2013, 06:47 PM   #3
Ken T's Avatar
Stand-by mode which means like you just turned on the camera, the LCD displays all the infos readily for shooting like shutter speed, aperture, ISO, Capture Mode ........ ie. not in Live View. There you will see graph of the 4 way controller and OK button, top is ISO, left is flash mod, right is shooting mode, and bottom is White Balance which is where you need to push.
05-13-2013, 07:02 PM   #4
VisualDarkness's Avatar
Green "shooting without controlling anything" mode.
05-13-2013, 07:03 PM   #5
Ken T's Avatar
Here is the screen where you can go to set WB
05-26-2013, 07:40 PM   #6
You might have already figured this out but just in case.
Go To INFO -> Auto Focus Active Area.
Most probably you have SELECT option active.
Change it to 1st, 2nd or 4th option.
Make sure you ain't in AUTO mode.
I struggled a lot to find this out, hope it works for you.
Cheers to your K30...
k-30, k-50, mode, pentax k30, pentax k50
K-30 Ready for Sale - but can't - Any thoughts? Mlcinema Pentax DSLR Discussion 12 05-04-2013 03:24 PM
can body cap be used for adjusting white balance. k5_freak Pentax Camera and Field Accessories 5 06-28-2012 09:45 AM
Odd white balance with K-x miltona580 Pentax DSLR Discussion 8 06-14-2012 11:33 AM
Why doesn't Auto White Balance work with manual lenses? vonBaloney Pentax DSLR Discussion 16 10-27-2011 03:00 PM
cold white balance in K-5 HanSch Pentax K-5 5 08-30-2011 01:23 PM
All times are GMT -7. The time now is 11:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
